vin number
F10 = F100
V = 239 cu in. V8
5 = Model Year 1955
K = Manufacturing Plant... Kansas City Plant
15074 Consecutive Unit No. beginning with 1000
Look at the truck rating data plate which should be found on the inside of your glove box door (that's where mine is anyway)
Under trans 3 is standard 3 speed
rear axle gives the ratio
Color code is the truck exterior color via codes Ask Earl, he has these codes
Hope this helps you
Good luck
Steve
