Core Support
Old Jun 14, 2014 | 08:19 PM
Shadowrider123's Avatar
Shadowrider123
Core Support
The core support in my 66 is pretty much gone below the battery.
Can I use an unmodified 64 support if I use the 64 inner fenders?
I don't see how I can modify a 64 to fit my 66 since Im missing key parts of the 66 support.
Any other options?
Old Jun 14, 2014 | 08:27 PM
6t6merc's Avatar
6t6merc
You should be able to find a usable - even mint - '66 item out there somewhere. I got a desert part for a couple hundred and I'm a long way from the desert. After sandblasting some rust was apparent but it was easily fixed.
Eric
Old Jun 14, 2014 | 08:57 PM
TxStang2010's Avatar
TxStang2010
65 supports will work with very limited modification . I have never tried swapping in a 64 and prior with the rounded inner fenderwells
Old Jun 14, 2014 | 10:03 PM
Shadowrider123
Ive had my eye out local for over 3 years with no success.
Old Jun 15, 2014 | 04:21 AM
mike k m's Avatar
mike k m
What modifications are required with the 65 supports?
Old Jun 15, 2014 | 06:03 AM
ddavidv's Avatar
ddavidv
https://www.ford-trucks.com/forums/1...or-66-use.html
Old Jun 15, 2014 | 01:04 PM
TxStang2010
battery tray mounting is different as is the rubber mounting as well (think the holes are a different size ) also the radiator mounts and a few holes to mount accessories are a bit off so . Good thing is that is still uses the angles inner fenders and will work without major headaches and fab work .
the article above is for 4WD , 2WD uses a different setup all together . the 65 support is available reproduction for 2WD .
NPD lists it for 1965 2WD
Old Jun 24, 2014 | 08:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
the article above is for 4WD, 2WD uses a different setup all together. the 65 support is available reproduction for 2WD. NPD lists it for 1965 2WD
C6TZ-16138-C .. Radiator Support = 1965 F100/250 2WD and 1966 F100 4WD
Old Jun 24, 2014 | 07:08 PM
Shadowrider123
ND, Are 65 and 66 inner fenders different?
I can buy a repop 65 core support, radiator, and battery tray.
So Im wondering what I would need to do to use a unmodified 65 core support in my 66.
Old Jun 24, 2014 | 07:17 PM
NumberDummy
Originally Posted by Shadowrider123
ND, Are 65 and 66 inner fenders (16054/16055) different?
So Im wondering what I would need to do to use a unmodified 65 core support (16138) in my 66.
Old Jun 25, 2014 | 09:07 AM
theastronaut's Avatar
theastronaut
You can use a reproduction support for a "patch panel" on your '66 support. That way you keep all of the '66 features. We couldn't find a decent radiator support so we ordered a reproduction and used the bottom half to repair the original RS.
Marking the cut lines.
Cuts cleaned up, making a template using masking tape.
Took measurments of various points so we could align the template, then stuck it on and sprayed silver paint to mark the cut line on the new RS.
Initial fit up of the two pieces.
After final fitting, welding, and smoothing the welds. Really surprised at how well the two pieces fit together.
After priming/painting.
Old Jun 25, 2014 | 09:53 AM
mike k m's Avatar
mike k m
Great work(theastronaut) on that support, now I know the best way too repair mine, was it the 65 2wd support you used ?
Old Jun 25, 2014 | 10:49 AM
Shadowrider123
I have a repop radiator so Im sure it is generic and can be made to fit any core support.
As I say, there is nothing left of the core support below the battery tray.
Im not a welder so I will have to have the missing pieces fabricated if I cant find a suitable 66 2x4 replacement. Along with the repop support, welding, fabrication, prep and paint, Im sure that Im looking at $600-700 to repair the support.
What Im looking for is a bolt in solution using a 64 or 65 4x2 repop support with the associated inner fenders and battery tray? My inner fenders are full of holes left by stuff the PO's had bolted there I would need them filled and I could use a new battery tray anyway.
Im not to worried about keeping that original, I just want it to look good and be functional.
Is that possible?
Old Jun 25, 2014 | 09:24 PM
garbz2's Avatar
garbz2
Early rounded inner aprons will not fit the 65 66 low floor cab.
Garbz
Old Jun 26, 2014 | 09:13 AM
theastronaut
We used the '64 and earlier support since that's all that was available when we started the project.
