Sponsored by: Real Truck
Winches
Old Jun 13, 2014 | 07:27 PM
GallopingForester's Avatar
GallopingForester
Winches
Rather seeing the two wheel trailer auction quest turning into a research project https://www.ford-trucks.com/forums/1319208-what-would-you-use-a-2-wheel-trailer-for-when-you-have-an-f250.html
...........I thought I might turn to other things that are on my list to help me for building my ranch.
Winches have LONG been on the dream sheet, first for the Forester and now for the F250, but they've been something I have yet to get around to. It's more likely on the -250 though, because it's not just a piece of emergency equipment but something that could be used to help in barn raising or after the trailer discussion, some to haul equipment on and off of trailers.
So down to basics at first. Where to put it? Almost always, I see them mounted on the front. I imagine for pulling stuff on a trailer, one just turns around the truck.....but I'm a babe in the woods here, so tell me.
Old Jun 14, 2014 | 12:54 PM
jetjockey99's Avatar
jetjockey99
I use 2 different winches, and yes you are correct you can turn around and use the front winch. I have a 15K Milemarker hydraulic winch on the front and use it 95% of the time, I personally would not have an electric winch as a primary winch, and I have a 8.5K electric on a mount that fits into a 2.5" hitch receiver for lighter duty use. For the electric I have a portable battery pack, with 2- 6volt golf cart batteries in series that I place very close to the winch with long 00 gauge cable that I hook to the truck batteries when needed. This portable setup allows me to use the winch with my garden tractor with out straining the electrical system on the tractor.
Old Jun 14, 2014 | 02:11 PM
GallopingForester
Like anything else, it seems like the winch requires a lot of research.....and decent bit of money.
But that's not to surprising when one is thinking about doing it themselves without a whole bunch of help. Without manpower, it becomes equipment intensive.
Let me toss one notion out there. Instead of putting the lighter duty winch on the truck, how about putting it on the Forester, my other car? When I am eventually able to live on the ranch, down the road quite a bit, both vehicles will be there....and I'm not getting rid of either.
Where does one go to find out about winches?
Finally, what all do you use your winch for?
Old Jun 14, 2014 | 07:15 PM
BossGasser's Avatar
BossGasser
2 things for now.
The winch should be mounted so it pulls directly in line with the frame rails.
Line pull is usually rated on the first wrap of the drum.
Old Jun 15, 2014 | 01:45 AM
BIGTRUCKBIGRV's Avatar
BIGTRUCKBIGRV
Winches - Electric Winch Guide - Your Guide to all Electric Winches
Old Jun 15, 2014 | 02:14 AM
djm1204's Avatar
djm1204
Not trying to brake any rules - if my comment does - will an administrator just delete it and advise me.....
You will find any and everything you might want to know about winches on the Jeep Forum - Jeep Enthusiast Network almost half the Jeeps used off road have a winch. I realize that you need a larger capacity winch for our trucks than a Jeep requires, but there is a ton of information over there.
Old Jun 15, 2014 | 09:04 AM
Big-Foot's Avatar
Big-Foot
I have a 9k winch mounted in the front of my bed on my F250 and it is set up with quick disconnects that also allow the winch to be removed and hung on the tow hooks in the front.
It was custom built (I did not build it - previous owner did) and has really come in handy.
I will try and get some pics up here..
An alternative is to mount to a bracket that plugs into a 2" receiver. If you have a front hitch receiver, you could move from rear to front easily as long as you have some good stout cables to go to the battery..
Im50fast
All Things Towing
55
Nov 10, 2017 07:56 PM
jonrjen
Apr 5, 2015 09:39 PM
njneer1
Dec 13, 2012 02:42 PM
A H DEVELOPMENT
Nov 8, 2010 04:09 PM
calf roper
19
Jan 26, 2009 09:08 AM
