throttle body cleaning
Old May 9, 2002 | 03:06 PM
camo 24's Avatar
camo 24
I took the throttle body off of my 96 F-150 and it has quite a bit of carbon build up in it. I want to clean it with chem dip but on the throttle body it says it should not be cleaned because it has a special coating on the surface of the bore and plates. Is there any way to clean it?
Old May 9, 2002 | 05:02 PM
rusty9's Avatar
rusty9
yes. i use the throttle body spray from the local auto store. the carb cleaner is the same stuff i think. just spray on and use toothbrush and rag. be sure to get new toothbrush for your teeth.
cheers,
Rusty,
Old May 10, 2002 | 10:09 AM
jim henderson's Avatar
jim henderson
Be sure to use a TB spray cleaner that says it is OK for the costing. Many newer throttle bodies have a kind of plastic coating on them to help lessen deposits(kind of like a teflon fry pan). Some of the older TB cleaners and carb sprays can remove the coating which would lead to increased deposits.
So read the lable or ask the parts guy(assuming he knows what he is doing).
Good Luck,
Jim Henderson
Old May 10, 2002 | 10:15 AM
mikej's Avatar
mikej
Post throttle body cleaning
Budman1962
2009 - 2014 F150
Jun 20, 2016 09:23 AM
GadgetGuy22
1997 - 2003 F150
May 26, 2016 12:03 PM
mpmccarthy
Aug 21, 2004 11:58 AM
volfan16
4 Cylinder Engines
Jun 10, 2004 02:26 PM
Exp4Life
Oct 17, 2001 05:25 PM
