First truck
Old Jun 11, 2014 | 11:37 PM
bovine71211's Avatar
bovine71211
First truck
So I just got my first real truck its my second vehicle my first was a 1994 ford explorer traded for this truck it is a 1988 Ford F350 got a 300 I-6 5 speed transmission i believe it has the 4.10 ratio in the rear end regular cab and long bed needs some work timing work clutch adjustment and it has a issue with fueling it when you put the gas in about a dollar in it comes almost spilling out the neck so it takes like 20 minutes for $20 its ridiculous and needs a new rear tank easy fix stuff will post up some pictures tomorrow i will need some help later due to the previous owner removing the a/c components and possibly heat to so i think i have vacuum lines going to nothing but it runs and drives fine going to my daily driver in two days time since i need it to go to work.
Old Jun 12, 2014 | 07:46 AM
rla2005's Avatar
rla2005
Congrats on getting a real truck! j/k
Welcome to FTE
Old Jun 17, 2014 | 02:43 PM
bovine71211
pictures
okay so i was finally able to get some pictures of the truck
Old Jun 17, 2014 | 02:45 PM
rla2005's Avatar
rla2005
Nice ride!
Old Jun 17, 2014 | 03:15 PM
bovine71211
Thanks. i got the timing issue fixed turns out didn't tighten the distributor also had to replace the solenoid due to it being burnt up from a loose connection and the negative battery cable was loose i'm wondering what else he didn't tighten down on it.
Old Jun 17, 2014 | 03:18 PM
bovine71211
if you notice the boat in the 4th picture that is the reason for the truck. lol
Ol School 79
85
Mar 26, 2017 03:34 AM
masonf150
22
Oct 15, 2015 03:38 AM
fordka
17
Oct 1, 2012 11:55 PM
Duct Tape Racing
41
Jul 10, 2011 12:51 AM
96sherm
23
Apr 5, 2007 12:56 AM
