Front Driveshaft Installation
Old Nov 21, 2003 | 03:35 PM
murphy's Avatar
murphy
I am in the process of installing a replacement front driveshaft on my 60 F100 4wd. The driveshaft I was told is correct is adjustable for length. Does the larger O.D. portion of the shaft go towards the transfer case, and do I use those "U" bolts to attach the U joints to the differential and TC case ?
Old Nov 21, 2003 | 06:16 PM
barry's Avatar
barry
The short end with the sliding yoke goes to the transfer case. You use the u-bolts to hold the u-joint to the axle and Transfer case. Make sure you use lock washers on these.
