Still working through more issues on my 1995 Powerstroke automatic 4WD. I am looking for new wheels since the stock ones I have are in rough shape. Not sure what to look for but found these, will they fit?
Firestone SteelTex Tires and Rims LT265/75 R16
8-Lug
Load Range E
265 75 R16
Set of 4 tires
Depends. If they're from a '99 or later Ford, they will NOT fit. Lug spacing is different. If they're from a Chevy or Dodge, they'll bolt up, but the offset might be different (and/or the hub bore may not clear). If they're from a '97 or earlier Ford, they'll definitely fit. They're within literally hundredths of an inch of the same outside diameter as the stock 235/85R16s, so no speedometer adjustment.
