Steering Column refresh
Old Jun 10, 2014 | 09:41 AM
Shadowrider123's Avatar
Shadowrider123
Im pulling the 3 speed power steering column out of my 76 parts truck sometime in the next week or two.
Can someone give me a list of the wear parts that should be replaced.
I have the shifter collar p/n D5TZ-7228 B, mine is broken and held together with a hose clamp.
I think I need the following:
Upper and lower column bearings (are they the same)
Upper bearing sleeve (is there a lower bearing sleeve)
Selector Arm Bushing & Insulator Kit
Column floor seal
Old Jun 10, 2014 | 03:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I think I need the following: Upper and lower column bearings / Upper and lower bearing sleeves / Selector Arm Nylon Bushings.
See pic of column below part numbers.
D5TZ-7228-B (replaced CODZ-7228-B) .. 3 M/T Shift Collar / Obsolete
1961/77 F100/250 / 1966/77 Bronco // 1960/65 Falcon/Comet / 1962/65 Fairlane.
RED TAYLOR FORD in Corning AR has 1 = 870-857-3518.
GREEN SALES CO. in Cincinnati OH has 10 = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has 62 = 606-787-5293.
F23Z-3517-B (replaced C7SZ-3517-D) .. Upper Steering Column Bearing / Available from Ford.
C3DZ-3517-A .. Lower Steering Column Bearing / Available from Ford.
B1AZ-3518-A .. Lower Steering Column Bearing Sleeve / Available from Ford.
D1AZ-3518-A .. Upper Steering Column Bearing Sleeve / Obsolete
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
2) E0SZ-7341-B (replaced C8OZ-7341-A & D5AZ-7341-C) .. Selector Lever Nylon Bushings / Available from Ford.
Old Jun 10, 2014 | 10:28 PM
Shadowrider123
Thanks for the p/n's and diagram.
CountryBumkin
Mar 30, 2017 07:29 AM
Chevmn56
13
Aug 31, 2015 12:08 PM
Mikes67F250
Feb 3, 2015 06:36 AM
OX2
15
Aug 1, 2012 05:14 PM
66crawler
13
Aug 28, 2010 12:16 AM
