86 a/c gone crazy
Old Jun 9, 2014 | 04:39 PM
jdmc148's Avatar
jdmc148
86 a/c gone crazy
can't figure out why my a/c will blow out the defroster vent when I go up a hill and out the a/c vent when I go down a hill. Please anybody help..!
Old Jun 9, 2014 | 05:09 PM
ctubutis's Avatar
ctubutis
Defrost is the default position to which the HVAC system will return during periods of low (or no) vacuum... it sounds like perhaps you don't have the vacuum reservoir properly hooked up? It's a grapefruit-sized plastic ball on the passenger side wheel cover and is attached to the vacuum system via a check valve.
Old Jun 9, 2014 | 08:34 PM
Franklin2's Avatar
Franklin2
That's it. Going up a hill you are opening up the carb and the vacuum goes very low. Going down the hill and cruising the carb is almost shut and the vacuum is high.
To keep this high/low vacuum from affecting the HVAC controls, they put a check valve in the line going over to the pass side from the engine, and than after that they put a Tee and hooked a ball or can in the line to store vacuum, and then another line ran through the firewall near the pass side hinge to feed the dash system vacuum.
If you can't figure it out, you might need to find a friends truck and look how it's hooked up, or go to a junkyard and see how it's hooked up from the factory.
Old Jun 10, 2014 | 12:34 PM
1986F150six's Avatar
1986F150six
A vacuum leak anywhere in the system can cause the symptoms. My son's 1984 F150 had just had a stereo replacement and during the install, a small vacuum hose connected to the servo motor which mixes the defrost and heater vent position was pulled loose. As soon as it was reattached, the condition was corrected.
Listen carefully for a hissing sound when the engine is idling. Check all vacuum lines and vacuum ports for openings. Don't forget that the PCV system and power brake booster can be sources of vacuum leaks.
I just found this, using the "search" feature. Open the link: https://www.ford-trucks.com/forums/1...c-control.html
By the way, welcome to the forum!
Old Jun 11, 2014 | 09:01 AM
jdmc148's Avatar
jdmc148
86 A/C
thanks for the help..! I did find the problem it was the vacuum line going to the little hinge motor was not seated good. one little push it was fixed! Thanks everyone for the advice
pecanguy
Aug 18, 2013 08:36 PM
LARIAT 85
May 24, 2007 07:59 PM
FordandSkeeter
Jan 28, 2005 09:03 AM
plaidad
Jun 12, 2003 12:01 AM
wildjon300ci
Oct 9, 2002 03:14 PM
