O/T axle help
Old Jun 9, 2014 | 01:38 PM
turbohunter's Avatar
turbohunter
O/T axle help
Hi Guys
I have a little problem I'm working on.
I bring it up on this forum because I know there are lots smart guys here and this is where I hang the most.
I have an axle under my '61 that I'm looking to either replace, or re gear. I'll take your ideas on which.
It looks like a Dana 60 but the model number says it's an 80. However I thought 80s were full floating and this one is not.
I can't quite get all the numbers off the housing but here are the ones I can see.
It has some short *** gears in it, prolly at least 4.56ish.
Would like to get that up to 3.50/3.70ish 'cause I've been driving it on the freeway quite a bit.
I'm also going to swap out my Jeepified toploader in behind the Y block to get 4 full gears.
My question is this, first dos anyone know what this really is?
Second, is it something I should keep or just throw a 8 or 9 inch in the truck and lose this thing? Just a cruiser truck with little hp.
Thanks for your knowledge and ideas in advance.
Old Jun 9, 2014 | 09:21 PM
Blue and White's Avatar
Blue and White
Not too familiar with that vintage. That said, truck D60's are generally full floating also. Mine is ('78 F250).
As what to do, how healthy is the engine? A warm rebuild with a little compression, cam and 4 bbl should be fine with a 9". If its "really warm/hot" and you want to drag race, suggest a D60 or race built 9" from Moser, Strange or others. Either of the above may be easier than re-working the '61 rear.
Please consider this a "bump".
Old Jun 9, 2014 | 09:26 PM
VocaTexas's Avatar
VocaTexas
I'm no expert on Dana axles, but I did find this page:
https://en.wikipedia.org/wiki/Dana_80
Just change the '80' to a '70' for it's page. According to the articles, the 70 has 3.5 inch axle tubes and the 80 has 4 inch tubes. That should at least help you decide if it is one of these two.
Old Jun 9, 2014 | 10:48 PM
EP145's Avatar
EP145
My buddy has a 60 F100 and had the same rearend and we swapped it for a 9 inch out of a 63. After it was all said and done different u joint and it needed bearings it would have been cheaper to have the Dana re-geared.
But now he has a 9 inch!
Old Jun 10, 2014 | 10:55 AM
turbohunter
It's just a warmed over 292 Y. So no problem with power.
I'm thinking if I found a cheap 8.8 or 9 inch, either would work.
Hah
It's got 3.25 inch tubes (aprox/tape measure)
40 inch spring perches
Yeah Im curious too about the price to re gear with the larger pinion vs just a quick swap.
I'll call and check it out.
TXTrailerdaddy
May 24, 2018 06:30 PM
hoss73ford
1961 - 1963 F100 Unibody
Jul 7, 2015 03:00 PM
Boger
Nov 6, 2012 06:56 AM
sparky69
Offroad & 4x4
Dec 26, 2005 07:23 PM
fordmudrunner2020
Offroad & 4x4
Sep 16, 2003 10:37 PM
