Wiper Arm P/N Needed
ND, I need a couple P/N's and any known stock, the first part is the wiper motor arm that mounts directly to the shaft of the wiper motor, it is about a 5/8" x 2+" piece. It is a two speed motor if this makes a difference.
The second is a two speed wiper switch (P/N and stock).......thanks as always, I am now starting the frame off re-assembly, I promise pictures will be coming for all of you guys, thanks for all of the assistance over the last couple of years, this vehicle is now going back together, thanks, m.
C4TZ-17A436-N .. Wiper Motor Output Arm-Use with 2 speed wipers - Stamped TH or TN / Obsolete
1965 F100/350 & 1966 F100/350 before serial number 788,001.
C4TZ-17A436-C .. Wiper Motor Output Arm-Use with 2 speed wipers - stamped TC / Obsolete
1966 F100/350 from serial number 788,001.
1966 F100/350: Two different two speed wiper switches.
C3TZ-17A553-E .. 2 Speed Wiper Switch - 4 terminals / Obsolete
1963/65 F100/350 / 1966 F100/350 before serial number 760,001.
C6TZ-17A553-B .. 2 Speed Wiper Switch - 7 terminals / Obsolete
1966 F100/350 from serial number 760,001.
