Is a 4" downpipe worth it
Old Jun 8, 2014 | 09:42 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
For those of you that don't already know I am in the process of a major engine overhaul. Which also means there is a very large hole where my motor used to be. There's not very many write ups about a 4" downpipe on obs truck because it just doesn't fit. But with the motor out it wouldn't be hard to do the necessary firewall modifications to make it fit. I know Darin figured his egts were 50-75* cooler with his 4" downpipe that he installed and I ask you guys that are pulling frequently with bigger injectors, would you do it or not? As I said it would be easiest right now so I may already have made up my mind but I am looking for other opinions. Thanks. Nick
Old Jun 8, 2014 | 12:40 PM
427 fordman's Avatar
427 fordman
Nick, if you have the time, now would sure be the time to at least make the room for one if you think you'd want one. Knowing it did help my egt's I'd do it again in a heartbeat. It was quite a bit of work, but means it helped I call it worth it. Now this is with a bigger turbo, I don't know how much it would help on a stock turbo. It sure wouldn't hurt, but I don't suspect that the difference in egt's would be as much.
It's all up to you. Even if you made the room and didn't go that big you'd have real nice clearance on a smaller one. Mine goes to 5 inch as soon as I could. My elbow shooting it to the back is 5 inch and the adapter to 4 inch is above that, then 4 inch the rest of the way up. Like I said, it is quite a bit of work between the downpipe and firewall modding.
Old Jun 8, 2014 | 12:44 PM
MOOSE_MACHINE
That's kinda what I was looking for. I think I'd rather do it now then wish I had later.
Old Jun 8, 2014 | 02:24 PM
breedo99's Avatar
breedo99
Originally Posted by 427 fordman
Nick, if you have the time, now would sure be the time to at least make the room for one if you think you'd want one. Knowing it did help my egt's I'd do it again in a heartbeat. It was quite a bit of work, but means it helped I call it worth it. Now this is with a bigger turbo, I don't know how much it would help on a stock turbo. It sure wouldn't hurt, but I don't suspect that the difference in egt's would be as much. It's all up to you. Even if you made the room and didn't go that big you'd have real nice clearance on a smaller one. Mine goes to 5 inch as soon as I could. My elbow shooting it to the back is 5 inch and the adapter to 4 inch is above that, then 4 inch the rest of the way up. Like I said, it is quite a bit of work between the downpipe and firewall modding.
Who sells the 4" dp? And which 5" exhaust did you use?
Old Jun 8, 2014 | 03:28 PM
427 fordman
I don't know who sells a 4 inch DP for these trucks, mine is a diamond eye super duty 4 inch downpipe modded to fit and then pieced together with a 4-5 adapter, 5 inch elbow, and some 5 inch stock, adapted to a 5 inch diamond eye catback system. SD downpipe has the right flange for my S366 turbo. No cat, just bought that system as it would work with what I was building in front it, muffler is in the stock place.
Old Jun 8, 2014 | 03:30 PM
breedo99's Avatar
breedo99
Ive done a little more reading and think ill wait for 4" dp until i need to pull the motor, but i found a diamond eye 5" system while ago with a 3" dp, may go with that
Old Jun 8, 2014 | 03:44 PM
427 fordman
That's a real good system. I'm sure you will be happy with it.
Old Jun 8, 2014 | 07:51 PM
FI460's Avatar
FI460
That's the same system I have. Clearance is a little tight around the spare tire, but I love it.
Old Jun 8, 2014 | 08:52 PM
oldbird1965's Avatar
oldbird1965
I'm thinking about this also.
Old Jun 8, 2014 | 11:02 PM
fordman67's Avatar
fordman67
I'm gonna b like all the cool kids....5"...outta da hood!!!!
Old Jun 9, 2014 | 02:17 AM
Canadian7.3's Avatar
Canadian7.3
I believe Irate diesel makes a 4" DP for their turbo upgrade kits
Old Jun 9, 2014 | 08:20 AM
LeoJr's Avatar
LeoJr
Aren't there some other turbo upgrades that require additional firewall clearance?
Old Jun 9, 2014 | 01:16 PM
MOOSE_MACHINE
Does anyone know if the 5" exhaust will fit around the 38 gallon oversized rear fuel tank
Old Jun 9, 2014 | 05:55 PM
oldbird1965
That's the same thing I was wondering, my 4" is right up almost against my 38 gallon tank.
Old Jun 9, 2014 | 06:07 PM
427 fordman
That's a good question guys. I've just got a stock tank and no spare down there so I had no issues. I couldn't tell ya.
