No Start PLEASE HELP
Old Jun 7, 2014 | 06:42 PM
FastTimes10's Avatar
FastTimes10
On Thursday I was coming home from work and my truck shut off, then I try and crank it on and and the batteries died after two tries, then my buddy jumped my truck with cables then it was shutting off 2 mins after the cables were off, so then we jump it again and it stayed on so I was driving home and it died out again, so we tow it home I pull the alternator off took it to get tested and it was bad, so I put a new one in and now the truck won't start, cranks but no start???
Old Jun 7, 2014 | 06:53 PM
KDAVID1's Avatar
KDAVID1
Are you're batteries good? Bad alt can damage them. Low volt is also bad for ficm. Do you have a odb2 monitor like scangauge II so you can get some live data?
Old Jun 7, 2014 | 06:55 PM
FastTimes10
Batteries
I'm going to get both charged now
Old Jun 8, 2014 | 08:34 AM
cheezit's Avatar
cheezit
Year , milage and mods. Any recent work done?
Old Jun 8, 2014 | 09:13 AM
npccpartsman's Avatar
npccpartsman
Profile says 03 with 200K+ miles.
Old Jun 8, 2014 | 11:13 PM
78fordman's Avatar
78fordman
Check charge voltage at each battery to make sure you don't have a cable problem between the batteries.
Sent from my leash using IB AutoGroup
Old Jun 9, 2014 | 12:10 AM
04badford's Avatar
04badford
With a bad alternator, the Batteries and FICM took a hit, you really need to load test each Battery separate and check FICM volts your FICM has main power logic power and Vehicle power (mp,lp,vp ) If you anything below 45 It's toast and needs to be repaired or replaced. A gauge to monitor as Mentioned is a must as this will show the good the bad and the Ugly, and the Ugly would be replacing the Injectors because of the Batts alt and FICM.
Old Jun 9, 2014 | 02:39 PM
FastTimes10
Got both batteries checked there both good and fully charged, new alternator and still no start???? When i sent my FICM 5 months ago to get checked i had got the extra volt added???
Old Jun 9, 2014 | 02:40 PM
FastTimes10
VOLTS*
i had sprayed ether on my air filter and it stayed on and shut off
Old Jun 9, 2014 | 03:40 PM
Per4mance's Avatar
Per4mance
Either is a bozo no no with these trucks,you need a scan gauge or torque or something like that to give up some numbers you got something going on
Old Jun 9, 2014 | 05:09 PM
FastTimes10
Idk if this counts but I have the SCT livewire and it's not throwing a code, I was Ganna check the volts on my FICM when I get home from work because if the bad batteries and bad alternator fried it I have it under warranty...... I mean I know a little about diesels but not alot...... What do u think it can be
Old Jun 9, 2014 | 05:36 PM
Poor'it in'her's Avatar
Poor'it in'her
we think could be never sprayed ether into your 6.0 cracks can and will form in your engine's cylinder walls and ruin your block and you need a gauge to get some real numbers, what he said
Old Jun 9, 2014 | 08:21 PM
04badford's Avatar
04badford
VOLTS*
You may have shorted or ate the MAF, where exactly did you spray it? you mite be able to spray MAF cleaner, but don't know other stuff is so Harsh
Gcoppola
Jul 10, 2019 11:11 PM
Billy 6.0
Jan 29, 2013 09:15 PM
BobbyB
Jan 14, 2011 09:19 PM
chadbellard
Oct 4, 2007 10:16 PM
TearDaClubUp
31
Jun 2, 2005 08:47 AM
