Sponsored by: Auxito
6.5ft to 8ft box?
Old Jun 7, 2014 | 05:42 PM
sorum87's Avatar
sorum87
Question 6.5ft to 8ft box?
I bought an 02 f150 with a 5.4 with a 6.5ft box. It has been rear ended and the frame rails are bent behind the rear axle. I was wondering if I could cut off the bad and extend the frame to fit an 8ft box. I have an experienced welder that can weld on frames, just wanted to know if it was possible.
Old Jun 7, 2014 | 06:25 PM
galaxie641's Avatar
galaxie641
The frame difference between the two is between the axles, you'd need to extend the frame, fuel/brake lines and harnesses right behind the cab.
Old Jun 11, 2014 | 06:33 AM
sorum87's Avatar
sorum87
Thank you galaxie. That makes a lot more sense, not really worth it for me then though
Old Jun 11, 2014 | 01:08 PM
exranger06's Avatar
exranger06
...And the driveshaft.
black water
18
Sep 12, 2010 12:23 AM
highboy250
Apr 15, 2008 10:39 PM
wickymustang
Paint & Bodywork
Mar 17, 2006 07:44 AM
flyhound
Dec 26, 2004 01:22 AM
1low50
May 12, 2004 10:08 AM
