hi all i have had a efi 460 from a 89 f350 in my 79 for a while now but one question. the computer is for a auto. since its for a auto its like its in park all the time and the rpms drop fairly slow which makes it annoying to shift my manual tranny. can i just unplug the computer and plug one in for a manual? or will i have to change wireing also?
its not deathly slow just enough make it irritating when shifting. ive cleaned the iac. this throttle stop screw you speak of. is it a manual adjustment like on carbs? and its still early here what is mlps?
Manual Lever Position Sensor - the glorified name for the neutral start/backup light switch on electronic automatics.
The throttle stop screw is just like on a carb, except you're NEVER supposed to change it from the factory setting. There are a few recent threads in one of the forums about how to put it back if you think it's been messed with.
