computer questions
Old Jul 8, 2003 | 12:41 AM
okiebronco's Avatar
okiebronco
computer questions
hi all i have had a efi 460 from a 89 f350 in my 79 for a while now but one question. the computer is for a auto. since its for a auto its like its in park all the time and the rpms drop fairly slow which makes it annoying to shift my manual tranny. can i just unplug the computer and plug one in for a manual? or will i have to change wireing also?
Old Jul 8, 2003 | 01:14 AM
steve83's Avatar
steve83
computer questions
If you think that's what's causing it, just find out the resistance of the MLPS in D or OD and add a resistor to mimic it.
But I think your IAC is bad, or the throttle stop screw has been reset.
Old Jul 8, 2003 | 09:26 AM
okiebronco's Avatar
okiebronco
computer questions
its not deathly slow just enough make it irritating when shifting. ive cleaned the iac. this throttle stop screw you speak of. is it a manual adjustment like on carbs? and its still early here what is mlps?
Old Jul 8, 2003 | 11:55 PM
steve83's Avatar
steve83
computer questions
Manual Lever Position Sensor - the glorified name for the neutral start/backup light switch on electronic automatics.
The throttle stop screw is just like on a carb, except you're NEVER supposed to change it from the factory setting. There are a few recent threads in one of the forums about how to put it back if you think it's been messed with.
