Codes Help
Old Jun 5, 2014 | 10:41 AM
diamondrcattle's Avatar
diamondrcattle
Codes Help
Service engine soon light is on. Can't get in to the dealer until the 18th...diesel mechanic on vacation. Went by O'Reilys to have the code read, but they don't have any explanation. P249F "Excessive Time To Enter Closed Loop DPF Regeneration Control" and P249C "SCR Time to Closed Loop" are the codes. It had wanted to regen a few times but I was in town. Drove 25 miles a few days ago and it never regened, but that was when light came on.
Any ideas???
2011 6.7L F-250 38k miles
Thanks
Old Jun 5, 2014 | 01:16 PM
darren32's Avatar
darren32
P249F - Excessive Time To Enter Closed Loop DPF Regeneration Control
Description: The powertrain control module (PCM) monitors the diesel particulate filter to determine that closed-loop control of a regeneration event occurs within a reasonable amount of time. This DTC sets if time in closed-loop operation is less than an expected threshold.
Possible Causes: Damaged EGT12 sensor
Fuel injection concern
Damaged diesel oxidation catalyst
Biased diesel particulate filter pressure sensor
Damaged diesel particulate filter pressure sensor
Diagnostic Aids:
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to Pinpoint Test RC .
P249C - SCR Time to Closed Loop
Description: The powertrain control module (PCM) monitors the amount of time elapsed until the selective catalytic reduction (SCR) system enters closed-loop control. This DTC sets when the time elapsed exceeds an expected threshold.
Possible Causes: Damaged EGT12, EGT13, or EGT14 sensor
Damaged SCR system components
Biased NOx sensor
Diagnostic Aids:
Old Jun 5, 2014 | 01:18 PM
darren32's Avatar
darren32
Pinpoint attached
File Type: pdf
Old Jun 5, 2014 | 03:06 PM
senix's Avatar
senix
wonder if you could take this out and run it hard and get it to go into regen and get it cleaned out?
Old Jun 5, 2014 | 08:44 PM
diamondrcattle
Any chance this will put me in limp mode? I need to go out of town with it. Thanks
Old Jun 6, 2014 | 12:02 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
I would go on a drive, 45 mph or above for 30 mins and see if it regens. If it starts a regen, do not interrupt it, stay 45 or above for at least 15 mins.
Just my opinion.
Old Jul 2, 2014 | 01:24 PM
djousma's Avatar
djousma
Any update on this? I'm curious what your fix was. I'm getting P249F and the dealer just reset the light and sent me on my why saying they didn't have enough information for diagnosis.
Old Jul 9, 2014 | 10:29 PM
pstroke67's Avatar
pstroke67
If vehicle is under 5 yr or 60k miles then take it back dealer and have them idle truck for whole day and try get concern to duplicate usually it's an egt sensor that reading bias if you don't wanna wait for dealer just buy all 4 of them and install them your self just be warn egts for 6.7 are on back order so dealer might mark up the price
djousma
6.7L Power Stroke Diesel
Jul 9, 2014 10:25 PM
parkland
6.4L Power Stroke Diesel
20
May 11, 2011 07:15 PM
greystreak92
1978 - 1996 Big Bronco
Mar 6, 2011 11:16 AM
Hester007
Aug 31, 2008 11:02 PM
totin_tools
Mar 23, 2008 09:52 AM
