Code 23 TPS help
Old Jun 4, 2014 | 09:58 PM
vtjvt's Avatar
vtjvt
Code 23 TPS help
I finally got my truck to pop a code, it is the code 23 tps signal voltage out of range or something like that,
Truck has a hesitation sometimes when speeding up, I changed the tps last summer but the problem never went away, I am getting 5.11 volts to the orange wire and something like .5mv to the brown, the green wire increases in voltage when I raise the throttle till about 3.0 volts then has a spot with no connection Then rises again. The old tps did the exact same thing, I even put it back in tonight to test it.
Is it just my bad luck that 2 are having the same identical problem or can something else be causing it???
Slip ford man
Jul 31, 2011 01:37 PM
96Bronco1
1978 - 1996 Big Bronco
May 12, 2010 05:37 AM
95f150
Sep 26, 2004 07:55 AM
aberfoyle
1983 - 2012 Ranger & B-Series
Aug 26, 2004 10:49 AM
BlueBronco
Dec 17, 1999 10:35 AM
