Question about hubcaps
Old Jun 4, 2014 | 04:13 PM
RedTaurus94's Avatar
RedTaurus94
I have decided that I want to put this kind of hubcap on my '72 F-100:
I see a few sets of them for sale on ebay and other places. Most say they are for a 16" or 16.5" wheel. My question is, are there more than one size of these caps? If not, will these fit my 15" stock-type rims? I sure hope so because I like the way they look!
THANKS in advance for the help!!
Old Jun 4, 2014 | 05:05 PM
JEFFFAFA's Avatar
JEFFFAFA
No F100 or later F150 wheels that am aware of has the correct mount area for these F250 caps.
Old Jun 4, 2014 | 05:20 PM
Keithfriend's Avatar
Keithfriend
My son has these hubcaps on his '68 F100. I didn't like them at first but they are growing on me. I like the look with the whitewall tires. These are 15" rims.
Keith
(By the way, I LOVE the new picture uploader. It's so easy that even I can do it.)
Old Jun 4, 2014 | 05:26 PM
greenmachine55's Avatar
greenmachine55
I used semi truck clips on my 16x7 steel rims 1970 to 1980 to mount my original F250 hubcaps on my 1955. It is pretty easy to do. You just have to drill a whole, screw, alittle bending for adjustment, and some patience. Let me know if you need more info.
Old Jun 4, 2014 | 05:27 PM
greenmachine55
I used semi truck clips on my 16x7 steel rims 1970 to 1980 to mount my original F250 hubcaps on my 1955. It is pretty easy to do. You just have to drill a whole, screw, alittle bending for adjustment, and some patience. Let me know if you need more info. See my profile pics.
Old Jun 4, 2014 | 06:02 PM
HIO Silver's Avatar
HIO Silver
FWIW... ND stated the following about the hubcap pictured above:
Be careful, these are TWO different diameters of these painted hubcaps: 10 5/16" & 11 3/4."
1967/68 F250's could have either innie or outie wheels. 1969 and later are all outies.
The outie hubcaps are also the same as 1967/77 F350, 1969/74 E300, 1975/77 E250/350.
There are also two different diameters of the stainless steel hubcaps.
Old Jun 4, 2014 | 06:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
These (TYPE 4) hub caps will not fit F100's, E/F250/350 & E300 only. Were available either painted or stainless, there's two different diameters, as it depends if they're innies or outies.
10 5/16" diameter - Use with innie wheels: 1967/68 F250 2WD & 4WD (rear only).
11 3/4" diameter - Use with outie wheels: 1967/77 F250 2WD & 4WD (rear only) - 1967/77 F350 - 1969/74 E300 - 1975/77 F250/350.
Wheel cover pictured in post 3 (TYPE 5) was introduced in 1966 F100 2WD/4WD as an option, used thru 1977. Also, standard equipment 1967/77 Bronco.
The 4WD cover, instead of an emblem, has a red plastic ring to allow the hub to poke thru, but...
You have to look close, because there were FOUR difference versions of this wheel cover.
Four different versions were available for 1966 Galaxie/LTD ( ridiculous!), one for F100/150 & Bronco.
The cone could be stainless or painted light argent, the emblem could be red/black or all black. F100/150 & Bronco have a stainless cone w/a red emblem or red plastic ring.
The cover pictured in post 3 is missing its black painted accents.
Old Jun 4, 2014 | 07:03 PM
RedTaurus94
Well, that stinks! Guess I'll have to pick something else. The Type 3 caps shown above are similar and might be my solution. However it works out, I want a small cap on a black rim with the Cooper tires I have with the big white letters. THANKS again for all the info!! You all are obviously on top of your game when it comes to parts!!
Old Jun 4, 2014 | 07:27 PM
NumberDummy
TYPE 3:
C7TZ-1130-G .. Hub Cap 10 1/2" diameter - Painted argent with black painted accents: 1967/72 F100.
C8AZ-1130-D .. Hub Cap 10 1/2" diameter - Stainless steel with black painted accents: 1968/69 Galaxie/LTD & 1968/72 F100.
Old Jun 4, 2014 | 07:28 PM
RedTaurus94
Thank you, ND!! Gonna start looking right now....
Old Jun 4, 2014 | 07:51 PM
HIO Silver's Avatar
HIO Silver
Consider a set of these... I found them in a late 60s Econoline hidden in a compartment under the built-in bed. Somebody's stash I suppose but they came home with me for a whopping $12.
There are also these off a newer Econoline. Shown on a 15x8 wheel.:
Old Jun 4, 2014 | 08:13 PM
NumberDummy
TYPE 7:
D3TZ-1130-A .. Painted Finish & D3TZ-1130-B .. Stainless Steel.
10 7/32" diameter: 1973/84 E/F100/150.
Old Jun 4, 2014 | 08:45 PM
RedTaurus94
Yeah, I have looked at those. They'd work fine. They're definitely on the list....
Old Jun 5, 2014 | 06:40 PM
RedTaurus94
Welp, strike one on my first attempt to acquire a set of the C8AZ-1130-D caps off ebay. Gonna keep looking. I have a set of the Type 5 caps on the 1973/79 diagram. I may have to sell them first, or figure out some kind of a trade if I am going to get what I am looking for.
Old Jun 5, 2014 | 07:16 PM
JEFFFAFA's Avatar
JEFFFAFA
Patience. You'll get what ya want.
