DEF fill interval
Old Jun 4, 2014 | 10:16 AM
WhëëlMå1's Avatar
WhëëlMå1
DEF fill interval
What is the time table? When I picked up my 2014 a month or two ago... the dealer did not go over this.
Also when should I dump the oil for the first time on this? Thanks
Old Jun 4, 2014 | 10:30 AM
2ndStroke's Avatar
2ndStroke
Depends on driving style, towing, city, etc. Usually around 1000 miles per gallon of def seems to be the norm. My tank would last oil change to oil change when I was using the stuff.
Old Jun 4, 2014 | 11:01 AM
BlackBeest's Avatar
BlackBeest
What he said...
As for initial oil change, varying opinions.... if it makes you more comfy to jump the dashboard reminder, go for the "1000 miles before heavy towing" interval, or the ole "3000 mile oil changes" interval, before letting the dash tell you when it's due
Oh and where are the pics
Old Jun 4, 2014 | 11:33 AM
WhëëlMå1's Avatar
WhëëlMå1
Will I get any sort of prompt when the DEF needs to be refilled (in dash)?
I will eventually get around to the pictures... took some, but havent had time to update FTE gallery with them
Old Jun 4, 2014 | 11:48 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Yes, it will give you a 600 mile (I think?) reminder.
Old Jun 4, 2014 | 12:30 PM
BlackBeest's Avatar
BlackBeest
lol, and it will continue to popup a mileage remaining interval message every.single.time.you start it, until you fill it back up.
Old Jun 4, 2014 | 12:38 PM
2ndStroke's Avatar
2ndStroke
Under system checks it will tell you if its full or when its half full as well.
Old Jun 4, 2014 | 01:13 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I get about 4600 miles between DEf fills on mine, half towing half not, all highway.
It will go lots farther if you aren't working it hard.
And you will get a low level warning at 500 miles to empty.
First oil change is up to you, I let the dealer do the first one since it was free at 5K, then I have been running them at a 7500 mile intervals since.
Old Jun 4, 2014 | 01:22 PM
senix's Avatar
senix
I seem to get about 5K for a complete def cycle.
There is a 800 miles to empty then it counts down..If I recall around 300 miles it counts down constantly.
Most dealers don't have the def completely full upon purchase so you may need it sooner.
I do 5k oil changes, a lot go by the minder though.
Old Jun 4, 2014 | 01:30 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I guess the low level warning works differently on XL's or XLT's without the fancy display screen between the tach and speedo. Base trucks don't get the DEF warning until 500 miles to empty.
Old Jun 4, 2014 | 01:56 PM
RedHorse1's Avatar
RedHorse1
Seems to be about a gallon per 1000mi. YMMV
Old Jun 4, 2014 | 02:59 PM
WildWildWest's Avatar
WildWildWest
About 25,000 miles since I topped my DEF tank off!! Pretty damn good, if you ask me!!
Sorry, couldn't resist...I've been deleted that long.
Old Jun 4, 2014 | 05:02 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Buying DEF:
Ford dealer........$20+ for a 2.5 gallon jug
Sam's Club........$11 for a 2.5 gallon Jug
Truck Stop Pumps (at the big boy diesel pumps).......$2.90 per gallon.
I always use the truck stops, so much cheaper !!!!
Old Jun 4, 2014 | 06:22 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Originally Posted by Sailor_Roy
Buying DEF:
A small truck stop a short way north of me(Corrigan TX) has it at the pump for $2.18.
Price at all Loves truck stops is $2.69 a gallon.
I've never bought a drop of DEF except from the bulk pumps at the truck stops.
Old Jun 4, 2014 | 07:49 PM
dualwheels66's Avatar
dualwheels66
Even Home Depot sells it now for $12 for the 2.5 gallon jug.
