390..points or switch?
Old Jul 7, 2003 | 10:10 PM
70XLT's Avatar
70XLT
Question 390..points or switch?
I just got "Dads old truck" He bought it new in late 69. points have worked for 34 years, should I switch to electronic igintion.
Old Jul 7, 2003 | 10:14 PM
sullyda1's Avatar
sullyda1
I recommend Petronix. Relatively cheap, easy to install, quick starts, smooth idle.
Old Jul 7, 2003 | 10:40 PM
HillbillyHellcat's Avatar
HillbillyHellcat
Pick up a remanufactured duraspark distributor from AutoZone with the cap and adapter and run it to a MSD box... It's very simple to wire up and you'll get a performance increase. I have used points in a few Fords but the Duraspark is pretty much problem free.
Old Jul 7, 2003 | 10:45 PM
jor's Avatar
jor
The electronic ignition is better but there is nothing wrong with a mechanical points system. Just make sure you set the gap and the dwell properly and it will run like a top. One thing about points: When you wash your engine down at the self-service car wash, you will always have that nagging uncertainty about whether you got those points wet and the old truck won't fire. This builds character and teaches humility. Good luck.
jor
Old Jul 9, 2003 | 07:43 PM
baitmaster's Avatar
baitmaster
In the 15 yrs I have owned my '72, I had changed the points too many times . 5 yrs ago I took 10 minutes and swapped to the Pertronix system. Haven't touched the dizz since.
Old Jul 9, 2003 | 08:13 PM
70XLT's Avatar
70XLT
Thanks for the advise. The Pertronix setup seems to be hard to beat.
Old Jul 10, 2003 | 07:15 AM
78f3504x4's Avatar
78f3504x4
I'm putting pertronix in my 71F1004x4 today, I'll tell you how it works out. Steve
