engine tempeture switch help
Old Jun 3, 2014 | 05:57 PM
F100trauma's Avatar
F100trauma
I'm converting my 77 F-100 302 from mechanical fan to electric fans and I just need help on getting the right coolant temperature switch that will get the job done any suggestions on which one should I get and from what vehicle, any suggestions I will highly appreciate it.
Old Jun 3, 2014 | 06:19 PM
psychlopath's Avatar
psychlopath
When I went to a two speed fan, I used Napa part number ECHFS151. I dont know what it came from, but I tapped a hole into the thermostat housing and put it there. The low speed went on at 190 and the high speed came on at some other temperature that I can't remember. Napa even sells the connector for it so you can make it look clean and factory.
That was a metric thread, straight I think, that was sealed with an aluminum washer.
A fan switch from an 80-something 4-cylinder Mustang may be an other option that would fit into a 1/2" hole if there's one somewhere on your block, but it's been years since I decided not to go with one and I've forgotten the temperatures on it
1FastGambler
Oct 8, 2012 07:56 PM
mercman86
2004 - 2008 F150
Mar 4, 2009 10:37 PM
boatnfish
1997 - 2003 F150
Jun 9, 2008 04:40 PM
Keepitrunnin
Mar 23, 2008 06:03 PM
Skandocious
General Automotive Discussion
67
Aug 19, 2007 02:01 PM
