quick help needed
Old Jun 2, 2014 | 04:28 PM
vatreefarmer's Avatar
vatreefarmer
quick help needed
At mechanic getting ready to install new oil filter base. Do we need to replace the entire base or just unscrew the 2 bolts to swap out the bypass valve assembly?
Old Jun 2, 2014 | 04:44 PM
vatreefarmer
Just pulling the filter standpipe and replacing the bypass spring assembly seems so much easier the pulling the motor apart to access all of the bolts for the entire assembly.
Old Jun 2, 2014 | 05:55 PM
npccpartsman's Avatar
npccpartsman
You are correct that it's a lot easier. Unless you plan on replacing the oil cooler (again?) it's easier to just remove the filter housings and replace the internal parts.
Old Jun 2, 2014 | 05:56 PM
vatreefarmer
Thanks. That's what we ended up doing. Sadly, it was no help whatsoever. Delta still at 16*
James Wagoner
65
Nov 12, 2023 07:57 AM
jtexfisher
Sep 13, 2014 09:16 PM
chetspencer
Aug 7, 2012 01:21 PM
allisonmo2
Feb 23, 2009 06:22 AM
firebug
Feb 29, 2008 09:39 PM
