Remove Matte Spray Paint!! Help!!
Old Jun 2, 2014 | 02:29 PM
Griswald's Avatar
Griswald
I have a 1989 f150 custom i6 300ci which I purchased about 6 mnths ago. The previous owner spray painted the top and bottom half of the truck with a Matte Black(**** quality) paint to cover up the worn out hood/roof of the truck which is typical for this generation. Well I think it looks horrible and want to remove it. Certain places have been chipping already so I think it shouldn't be too difficult.
(I have a 3000PSI pressure washer at work with hot water which has helped take small chunks off)
Could questions:
-Any products to use that will help remove it?
-Will the paint underneath be completely destroyed?
-Could I use clay bar to remove it?
-I have some rust on the rocker edge should I avoid removing that paint?
That's all I can think of if anyone could give some pointers that would be great!
will post some pictures.
Old Jun 4, 2014 | 06:50 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Clay bar won't work. Only chemical mild enough to not damage underlying paint would be lacquer thinner and I doubt that will work. If it's rattle can primer, "maybe". The clear coat was more than likely deteriorated resulting in the cover up.
Old Jun 5, 2014 | 02:50 PM
TruckDaddy's Avatar
TruckDaddy
You need to find someone in your area that soda blasts. Soda blasting will remove it without damaging the metal. However, after soda blasting, you will need to paint it ASAP to prevent rust.
Old Aug 1, 2014 | 10:29 PM
RigTrash601's Avatar
RigTrash601
Looks like it will either need to be sanded completely, or blasted. Either way, a new paint job is in order.
jrockdiddy
Oct 7, 2017 09:55 AM
96halfton
Mar 1, 2017 03:22 PM
Odisvan
15
Jul 19, 2015 10:52 AM
FordF350Baby
Appearance & Dress-Up
Oct 25, 2007 10:01 PM
maximumhorsepower
Paint & Bodywork
Apr 6, 2003 07:28 PM
