Yesterday jump in truck head out and when I go to use right (passenger) blinker and it doesn't stay on. Left side works fine. It will stay on if held but on it's own it blinks like 4 times then shuts off. Any help would be appreciated Thanks!
Side note not sure if connected but a couple days before was using wipers and when I shut them off it was still like it was on intermitting. It happened a couple times but seems fine now, but then with the blinker I am wondering if it is something in there.
(and did u know you can push left to turn on left signal and push left again to turn it off ?)
Originally Posted by msgtord
He has an 04.
And he has a bad switch.
My bad haven't updated profile since I joined. It is a 2011 F250 xcab sb 4x4 6.7. I figuired I would have to do that. Sucks 52,000 miles already had a short which stopped blinkers from working. Corroded wires caused by rubbing now a bad switch and out of warrenty
Anyway thanks for any and all help.
Oh and of course it is inspection month
Well I think the wipers are involved. Last night went out and blinker wasn't working but it was raining and when I got back to house and went to use blinker to turn in driveway and it worked.
