96 efi 460 performance
Old 06-02-2014, 11:03 PM
cbakker's Avatar
cbakker
cbakker is offline
Originally Posted by Diesel_Brad
Do not cut the air intake coming from the grill. That funnels in cool air instead of sucking hot engine bay air. Actually the 300 6cyl and the 460 air inlet tube is a desirable one to have
This is correct. I only cut off about 3/4" off the end of mine where it sticks through the rad support. This allows more of the outside cool air volume to flow to the filter. Pre-filter air volume is a big factor in post filter volume and velocity.
Originally Posted by mflo7.5
MAF trucks do not have the air horns
Thank you mflo, I was unaware.
Old 06-03-2014, 12:35 AM
fatkidjake's Avatar
fatkidjake
fatkidjake is offline
If I remember correctly, isn't there a gear set from a 429 you can install to get rid of the retarded factory timing?
Old 06-03-2014, 01:12 AM
crewcab96's Avatar
crewcab96
crewcab96 is offline
I believe the EFI 460's came with the zero timing unlike the retarded timing like the pre 87.
Old 06-03-2014, 02:09 AM
Crewcabber's Avatar
Crewcabber
Crewcabber is offline
Yeah I wasn't very clear on that if you look down between the grill and the radiator just to the right you can see where the air tube comes thru remove the air tube and cut just the curved part off.
Old 06-03-2014, 02:15 AM
crewcab96's Avatar
crewcab96
Ok ill take a look tomorrow. I have another question. It first started on just my rear tank but now both are doing it if it sits all day at work or overnight it will fire up and die several times before it will actually stay running. Like the fuel is bleeding all the way back to the tanks. Any ideas what would cause that? And could that have something to do with my lack of power? My truck is a gas guzzling gutless land yacht.
Old 06-03-2014, 08:58 AM
cbakker's Avatar
cbakker
cbakker is offline
Originally Posted by crewcab96
Ill do a compression test. What size injectors should I go with? And what do you mean by the number? Where do I find that? Once I do all the add ons who should I have build be a custom pcm?
Stock injectors are 24lb/hr. and are sufficient for up to ~375 hp. The catch code is on your PCM, but since you have a '96, it should also be conveniently located on the bottom drivers side of the hood directly above the fender well. It should be a 5 digit alpha-num. combo for an EEC-V. I'm not sure where you are at or what is available for speed shops in your area, but you can buy a quarter horse chip and binary editor from Moates.net and DIY pretty reasonably. Stay away from an aftermarket PCM, as your current one is already capable of many things that the aftermarket is not.
I don't have much exp. with this but my guess is that your sending units are shot or your sender relay is. How long did you drive it on one tank?
Old 06-03-2014, 02:08 PM
crewcab96's Avatar
crewcab96
I go though at least a tank a week and switch back and forth and its been getting worse
Old 06-03-2014, 04:57 PM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
Don't blow your money on a K&N or other "performance" filter. All it will do is lighten your wallet and allow more dirt and sediment into your engine. If you had a race engine turning 7500 RPM then it would be a good choice, however a plain paper filter will flow more than enough for what you have.
Old 09-11-2022, 12:38 PM
S.lowe's Avatar
S.lowe
S.lowe is offline
1st Gear
Performance help
Sorry if posted the wrong way or in the wrong plus this is my first post on here I have a 96 f350 4x4 crew cab 460 efi with a zf5 Trans I am looking for some power increase and performance already have aftermarket exhaust but other then that it stock healthy but no other performance parts any ways I use it for hauling and towing plus it's just a fun truck to drive but would like to get more power and it would be nice to see better fuel mileage but I don't expect to get 20 mpg any suggestions would be appreciated I have been looking into performance chips but can't find one that I know will work
Old 09-11-2022, 12:57 PM
SFaulken's Avatar
SFaulken
SFaulken is offline
You'll get better response starting your own thread, rather than resurrecting an 8 year old one.
Old 09-12-2022, 12:16 PM
cbakker's Avatar
cbakker
cbakker is offline
Thanks for bringing me back!
Set base timing to 12 degrees btdc. Remove spout connector on the inner driver fender before setting timing. Best bang for your buck.
90f150matt
01-02-2017 01:37 AM
jeremy2008
Air Intakes, Air Filters & Ram Air
12-19-2011 03:37 AM
threefiftyone
01-04-2011 11:34 PM
cchimuk
07-22-2009 05:52 AM
Fair 96
08-09-2004 08:36 AM
Quick Reply: 96 efi 460 performance
