new tires problems
Old Jun 2, 2014 | 10:01 PM
ShaneNP123's Avatar
ShaneNP123
Originally Posted by 79ford matt
Does 8pr sound like what I am missing
No, that just means 8 Ply Rating.
Old Jun 2, 2014 | 11:46 PM
78fordguy's Avatar
78fordguy
Originally Posted by ShaneNP123
h
Not missing anything, common tire measurement system years ago.
Here's a conversion chart
http://www.tirerack.com/tires/tirete...sionchart.html
Not sure what your looking at but the only thing I see that the op has said is 7x15 he still has not said the height of the rear tires.
Old Jun 2, 2014 | 11:48 PM
78fordguy's Avatar
78fordguy
Originally Posted by John R. Thomas
Why would an F-150 have different sizes on the rear?
That's not stated on any Ford lit. I have.
They dont, the OP put different sizes on his truck.
Old Jun 3, 2014 | 12:31 AM
ShaneNP123's Avatar
ShaneNP123
Old tires that use that measurement had a circle cross section, the width and the sidewall are the same measurement, depending if it's a .80 or 1.00 aspect ratio.
Example, a 7.00-15 tire would have a width of roughly 7 inches, and a sidewall measurement of roughly 7 inches.
I'll take a guess that the OP's tires are roughly 29" tall, and probably bias ply tires.
Old Jun 3, 2014 | 06:46 AM
buttwheat's Avatar
buttwheat
I'm not sure what is meant by it walks but I but on a brand new set of Genaral ac grabbers and the first 30 or so miles felt like I was on ice and the truck would want to dart around. I'm not sure if some tires need to break in or something.
Old Jun 3, 2014 | 07:04 AM
Jklnhyd's Avatar
Jklnhyd
When i bought my truck a year ago, the PO stated that it sat for about 10 years from his PO. I drove it for a few months, and ended up throwing about a 12" piece of tread off on the freeway because of dry rot.
Maybe you have same issues going on
Old Jun 3, 2014 | 08:26 PM
79ford matt's Avatar
79ford matt
Finally found someone who runs similar tires I do said his does the same just not as bad. I'm going to do some playing around and see if rims help get another balance and widening the rear stance. Can't hurt worst case ill do more research before I buy next time. Thanks for the help.
Old Jun 14, 2014 | 12:02 PM
Twanstyle's Avatar
Twanstyle
ok so just my 2 cents
Dulles are on the rear of vehicles so you steer with the skinny front
so just in concept skinny on rear would make for more rear steering
also i just switched my rears for larger muds aprox 2.5 inches wider and i no longer hop over the deep man holes they refuse to fix near me
Old Jun 14, 2014 | 12:49 PM
John R. Thomas's Avatar
John R. Thomas
If you drive on paved roads, store your vintage truck in the winter, why buy the
wide tires with the aggressive tread? Leave that to the dudes that live out in the
country where the roads are not paved. (235-75RX15 white stripe)
Old Jun 15, 2014 | 06:32 PM
newto78f100's Avatar
newto78f100
I work in the tire industry and you should not mix radial and bias ply tires. I don't know the science behind it but do know that it causes vehicle wandering. The 7.00-15 would be a bias ply construction. Try two more radial tire and see if it helps.
fordboy5894
29
Jun 17, 2021 09:30 PM
parkland
17
Jan 26, 2010 06:14 PM
rusty7983
Apr 17, 2007 08:52 PM
nickp333
Mar 27, 2005 10:01 PM
junkyarddog86
Bronco II
Mar 12, 2003 11:40 AM
