A battery question????
Old Jun 1, 2014 | 05:38 PM
kermmydog's Avatar
kermmydog
Question A battery question????
I was wondering what is the difference between a 6 volt heavy duty commercial battery VS a 6 volt deep cycle?
Will the heavy duty battery work as well for RV & SOLAR use?
I found a couple of Exides at Tractor Supply with like 1170 cranking amps with 300 amp reserve. 975 cold cranking amps $99 ea.
Thoughts???
Old Jun 1, 2014 | 06:34 PM
RV_Tech's Avatar
RV_Tech
Thoughts???
Plates are heavier in a deep cycle battery and handle discharges/recharges better. Batteries designed for starting have thinner plates to increase plate to acid contact area producing more current more rapidly. If it is for your RV, buy the deep cycle. They will outlast batteries designed for starting.
Steve
Old Jun 1, 2014 | 08:31 PM
senix's Avatar
senix
I have an exide in my 5er, deep cycle. Good battery.
Old Jun 1, 2014 | 08:38 PM
kermmydog's Avatar
kermmydog
Smile
Steve
Thanks Steve. I figured you would have my answer. I'll follow your advice. Thanks
jed1894
Nov 2, 2015 04:16 PM
firemanpat29
May 12, 2009 12:53 PM
tjcnok
Electrical Systems/Wiring
Oct 1, 2008 08:10 PM
dannacc
Garage & Workshop
Feb 28, 2005 04:29 PM
