Re-curving a distributor?
What seems to be the problem? Is the vacuum advance working ok?
Some additional information to help you.
Vacuum advance- direct manifold vacuum or timed port? - Ford Muscle Forums : Ford Muscle Cars Tech Forum
And one more I found useful snipet I found useful.
"Yeah, it took me a while to fully wrap my head around manifold based timing since I'd had ported timing beat into my head for so long. Once I finally got it, it really is six or one half dozen of the other- just depends on what the end goal of the motor is. I get better economy and down low throttle response with manifold timing, but cleaner emissions and better part mid-throttle response with ported. In the end, manifold was just better for me all around.
One thing you need to really be careful about is your total advance- on a typical carbed ford head you're looking at a max of about 40*, especially in a truck.
With an EFI head it's down around 36* or so.
Over this and you can have non-audible detonation that will destroy a motor. Not catastrophically, but in the course of 10,000 miles or so.
Keep in mind, this does NOT include vacuum timing- just initial and mechanical. You can advance out to high 50*'s under low load cruise with no problem since once you load up the vacuum will go away and cut timing back.
Here's the "how to" short version.
What I like to do is advance my timing until the motor just runs perfect at idle and record what advance this is.
Then apply vacuum to the can and record what the vacuum adds.
Now subtract what the vaccum adds from your "perfect running timing". This number is now your initial timing.
Now, yank the distributor out of the truck and TOTALLY disassemble it. You'll see a rotor with two slots in it down under the advance plate. each slot will have a number followed by the letter L.
In one of these slots a little tab will be sticking up. Record the number written by both slots. Now multiply these numbers by two. These numbers are how much mechanical advance your distributor will allow.
Now, you want one of these numbers plus your initial timing (NO VACUUM) to add as close to 40 as possible without going over. Make sure the tab i referenced earlier is in this slot. if both tabs get you over 40 you have some work to do that i'm not going into right now.
While you're in there, buy a set of quick advance springs to put in. The ones I used were Mr. Gasket and cost about $7 at autozone. This will bring the mechanical advance in A LOT faster which you definitely need with manifold vacuum.
Put it all back together, set it to your new initial timing, hook the vacuum can to manifold vacuum and enjoy your newfound performance."
"I'd start by determining how much mechanical advance you have, then set my initial advance accordingly so you achieve 32-36 degrees total (as long as you don't experience detonation).
You can determine mechanical advance by pulling the breaker plate and seeing which advance slot the dizzy is using, the numbers will be stamped on the reluctor arms (only one advance slot is used) multiply this number by 2 and that's your mechanical advance.
Example: a 13L advance slot = 26 degrees mechanical advance, so you'd want to keep the initial advance in the 6-10 degree range to avoid spark knock.
Every vehicle/engine is different so you'll need to see what works best for your particular application, but the above numbers should get you in the ballpark, check out the link below it'll make things more clear than me trying to explain."
Duraspark_distributor_recurve_instructions_index
