heater core question
Old May 30, 2014 | 05:54 PM
captain2207's Avatar
captain2207
I'm in middle of taking dash off and can't figure out how to get right side loose.it is completely blown apart and right side just won't budge.oh I have a 01 expo.god I want to knock ford engineers out.$1000 for A $80 part so you can be human and have heat.this is absolutely bs.just ranting...
Old May 30, 2014 | 11:09 PM
alloro's Avatar
alloro
Must've missed a bolt on that side.
Are you replacing the heater core or fixing the blend door, or hopefully both so you never have to do this again?
Old May 31, 2014 | 06:53 AM
BAD RONALD's Avatar
BAD RONALD
The guy points to every bolt and connection:
Old May 31, 2014 | 10:22 AM
captain2207
Thanks on the video.still a nightmare.ill keep you posted on results.
Old May 31, 2014 | 11:08 AM
captain2207
Long shot here but,is anyone in or close to east Texas that wants to make few extra bucks?
Old May 31, 2014 | 02:24 PM
BAD RONALD's Avatar
BAD RONALD
The dash doesn't need to come all the way out. Just pull it away enough to access the blend door and heater core. Cut the tubes on the bad heater core with a short hacksaw for easier removal and push the connected ends through the firewall to take them apart. Do not over wrap the replacement heater core with foam or you will create problems for yourself.
This job is a PIA but doable. Stick with it.
vanceboroguy
Nov 24, 2014 09:09 AM
redneckbrat
1983 - 2012 Ranger & B-Series
Sep 30, 2006 11:25 AM
73Riviera
Sep 8, 2006 02:08 PM
