A\C affected by temp gauge?
first your engine temperature DOES effect the A/C. If it is out of "normal" range as determined by the engine computer, the computer opens the WideOpenThrottle relay shutting off the A/C.
secondly you must remember that your gauge uses a different sensor than the computer.
how to repair:
FIRST it is imperative that you make sure you do not have a coolant leak. The location of these sensors is on the top of the engine. If the coolant is low, they will not read it properly and the computer goes goofy.
If your coolant is low, correct the leak, fill the system up and see if that corrects the problem.
As you have indicated a continuously cooler running engine, I suspect that you have the same problem as mine. The computer sensor went out of range causing the computer to think the engine was overheating.
Don't panic. It is an easy fix. Pick up a new sensor ($15 at Autozone). WITH A COLD ENGINE. Locate the old one under the hood (it will be near the thermostat and has TWO wires going to it. Get the new sensor ready by putting teflon tape on the threads. Remove the wiring from the old sensor. Remove the old sensor and quickly screw in the new sensor. If you are quick you only loose a couple of ounces of coolant. plug the wires back on and enjoy.
Good luck
how to repair:
Good luck
okay two things
how to repair:
Good luck
Since you like to be quoted, I'm going to quote you again!!
First, the PCM only senses a coolant temp TOO HIGH, not TOO
LOW.
Second, he is complaining about his temp gauge reading too low,
why would he replace the ECT sensor for the PCM? If the temp
gauge is reading too low, then if the problem is a sensor, it will
be the gauge sensor (with a single wire connector), not the
ECT sensor.
This is 100% tried and true- been there done that technology. It drove me over the edge until I figured it out.
You can quote me on that.
PS if you check, i'll bet a quarter he has a lot of pinging at highway speeds from the computer over advancing
is a newer model. If so, you don't have an expansion valve, you
have a capillary tube (orifice). I suspect that your compressor
has a bad valve in it. To verify this, try closing off (pinching) the line going to the evaporator. If the low side doesn't go into a
vacuum, then this will confirm it's the compressor.
