Anyone seen a link for an OBS Trucool 4739 installation write up? Doesn't up in a search. I have a '97 F-350 PS 7.3L E4OD and A/C. Wondering about the bracketry and location.
i have the same cooler and mine is bolted to the back of the bumper where the holes are no need for brackets it fits perfectly and i got hydraulic 90 degree fittings so the hoses come out the top
Look at the link Alex put up. I just bent and used the brackets that came with it iirc to fasten it to the core support. If you do it like Rodney of course it will be a little different. It's just a matter of removing the old one and installing the new one wherever you want and running hose to hook it up. If you use the thermal bypass for warming the trans it matters which line goes where. If not, it doesn't. I used to use it, but took it off a year or so ago.
