Sponsored by: Auxito
Will not turn over, shift lock solonoid, cable?
Old May 28, 2014 | 10:44 PM
Charlie Tee's Avatar
Charlie Tee
Working on my bosses 97 Econoline conversion van. The steering wheel was flopping in the breeze, gear indicator was off and some of the time it would be in reverse when you thought it was in park. Checked the torx on the shift cable plate and they are tight. Replaced the 2 bushings on the shift column. They tightened up the steering wheel flopping around. I checked the shift cable and it appears to be in good shape.
It would start sometimes if you worked the shifter in park or moved it to neutral. Now it will not turn over. Shift lock actuator does not appear to be working. Does not lock it park. No continuity between any of the three pins with the actuator pushed in or out. If you turn the key you can take it out of park without pushing on the brake.
Really do not know the series of events that have to occur to make it turn over. Any advice on how to trouble shoot the problem would be much appreciated.
Old May 28, 2014 | 11:24 PM
Torky2's Avatar
Torky2
I think you will have better luck if you post your question in the Van Forum, which is here:
1968-2013 Full Size Vans - Ford Truck Enthusiasts Forums
Alaska1
Jun 12, 2017 11:05 PM
Thomas Hutchins
1997 - 2003 F150
Aug 25, 2014 09:49 PM
98EXPEDITION1280
Apr 23, 2011 03:03 PM
nintey4f150
15
Jul 30, 2010 07:15 AM
kidoo
Mar 27, 2007 07:25 PM
