I have a 2014 f350 extended cab short box, I.did a 1.5" level.kit and it has the snowplow prep so the truck sits almost dead level. I put on the wheels from my 07 I had with BfGoodrich A/Ts 305 65 R18 to me they seem too small. I am worried 35 12.5r18 will look too big. Im happy with the amount of wheel well filled with the stock 20s but thats a 34" tire. Can anyone with similar situations post pics or offer advice? I want a 34" x 12.5 but its not made anywhere.
Mine is a stock 250, and tires are 295/70/18, which is roughly 34.5 x 11.5. My wheels are +1 mm offset. I have no rubbing at all, and the wheel wells are pretty full.
I would think 35's would be no problem with your truck, but the 12.5 wide may rub.
I put a picture in my profile. Tried to post it here and it was huge!
How do I add pictures? I gotta check my receipt on my wheels to see what the offset is. It was just right with these tires on my 07 but the new body style has puffy fenders lije built in flares so the body is about 3/4" wider
ok here are some quick pictures. My 2007 was a F350 with 2 1/2" front level kit stock rear blocks the 305 65R18 tires were just right
Here are the same rims and tires on my 2014 F350 with 1 1/2" front level kit and stock rear blocks. I think the "built in giant fender flares" dwarf the tires
