Water Pump Leak
Old May 27, 2014 | 07:49 PM
Avid_Stroker's Avatar
Avid_Stroker
Water Pump Leak
Hello fellow OBS PSD owners!
So I had my water pump done around 150K, about 6 months ago, but within the last couple of months a little hex bolt/screw on top of the the water pump housing has started leaking whenever the truck sits the pressure presumably makes the coolant weep out. The new pump is a motorcraft but I haven't been able to find any info on that little bolt/screw.
I've tightened it some since it wasn't real tight but it still leaks. Would it be safe to use thread locker? Any advice is greatly appreciated!
Old May 27, 2014 | 08:10 PM
madpogue's Avatar
madpogue
Thread locker is to keep threaded fasteners from loosening. This is neither a fastener, nor is it loose (presumably). For this application, you want a thread sealer.
Old May 27, 2014 | 08:12 PM
Avid_Stroker
Thread sealer is what I meant originally, couldn't think of the word. What sealer would you recommend? Also, what exactly is that bolt for?
Old May 27, 2014 | 08:57 PM
fordpride's Avatar
fordpride
Um isn't there suppose to be a temp sensor where that plug is ?
Old May 27, 2014 | 09:10 PM
Avid_Stroker
If you look in the second picture, you can see part of the wire that goes to what I presume is the temp sensor. Its a little bit behind that plug.
Old May 27, 2014 | 09:31 PM
fordpride's Avatar
fordpride
Ok. I wonder why they are putting two holes now.
I have a brand new ford pump in the shop that only has one hole
Old May 27, 2014 | 10:04 PM
Avid_Stroker
I have no clue, my shop kept my old one and I never really looked at it before it got replaced. My temp gauge still works, or does whatever the stock gauges do lol. After the pump and the flush though its run much cooler. Great avatar fordpride btw!
Old May 27, 2014 | 10:09 PM
Avid_Stroker
The leak from that plug only leaks enough so that a few drops run down the front of the motor and accumulates a couple of drops on the crank pulley. Whenever the truck is cold the belt squeaks for about 5 minutes, could this be from the leaked coolant getting on the belt or pulleys? Drives me insane in the mornings.
Old May 28, 2014 | 12:35 PM
IDMooseMan's Avatar
IDMooseMan
Yes. I've used Oatey's sealant with great results. You can find a tube at Lowe's.
Old May 29, 2014 | 09:36 AM
Avid_Stroker
Thanks for the advice, just checked that plug and there appears to be no leak. Only time will tell, thanks a lot.
Old May 29, 2014 | 05:54 PM
helifixer's Avatar
helifixer
I believe the short stem thermostat pumps have always had that extra plug. this could be a '94 or '95 truck with a short stem pump. tough to tell for sure from the pics but the last one looks like the lower hose pipe is part of the pump and not bolted on.
Old May 29, 2014 | 06:14 PM
Avid_Stroker
It's a 95 F350 SRW, I can take some better pictures since it was dark when the first ones were taken. I know the pump is brand new, had to wait for it to fly up from Houston.
Zephyrhills Ford
Oct 7, 2010 03:28 PM
gofast51004
Mar 5, 2009 08:53 AM
b4hntn
1978 - 1996 Big Bronco
Jun 21, 2008 05:51 PM
wheressinatra
Oct 16, 2006 05:28 PM
Scott's 88 F150
Mar 8, 2004 07:19 PM
