Tranny Shudder
Old Jul 7, 2003 | 02:13 PM
62BigBlue's Avatar
62BigBlue
Exclamation Tranny Shudder
Just picked up my 5th Wheel trailer that weighs in at about 7000 lbs. When starting out from a dead stop and having to give it a fair amount of pedal, I notice a slight shudder until build up a little speed. It doesn't do it if I start out gentle or without the trailer. Is this normal or a sign of impending E40D problems?
The truck is a '93 F-250 Supercab with 460.
Thanks,
Old Jul 7, 2003 | 06:22 PM
jim henderson's Avatar
jim henderson
Tranny Shudder
One of the guys posted earlier that this may just be a sign of a heavy load or the tongue weight being too high or improperly adjusted hitch or rig. It was posted last week I think and is probably under towing or trannies.
Torque Shudder is usually more of a problem when accelerating moderately from about 40 or 50mph or so. It is the TC clutch slipping and the TC clutch is not normally locked up from a dead stop. It also won't show up under hard acceleration since most TC clutches unlock under heavy load. They lock up during cruise or gentle acceleration. If you get a shudder then, it may be torque shudder.
Good Luck,
Jim Henderson
Old Jul 8, 2003 | 08:29 AM
62BigBlue's Avatar
62BigBlue
Tranny Shudder
Thanks, Jim. That is an ease to my mind.
Old Jul 14, 2003 | 12:04 AM
Scooter29's Avatar
Scooter29
Tranny Shudder
Just another tid bit. Crawl under and chech the bushing in between the trans and the crossmember. You may have busted a bolt or split the split bushing and a pc. is gone. You may want to replace it with a poly pc. or stock, depending on how often you tow. Good luck....
Old Jul 14, 2003 | 12:27 PM
62BigBlue's Avatar
62BigBlue
Tranny Shudder
Well, Fish Lake was great and tho I still feel a shudder when I start out and a low growl goingup the steeper hils, nothing blew up. I decided I didn't really need to break any 0-60 records so unless absolutely necessary, I ease inot the low teens before applying mu pedal pressure.
I did change the fluid before leaving and it did make a big difference, just didn't get rid of all of the shudder.
I will check for that bushing abd see if that is in poor shape. Thanks for the help.
Old Jul 14, 2003 | 12:34 PM
jbalestri's Avatar
jbalestri
Tranny Shudder
Check all u-joints and the center carrier bearing. That center carrier bearing may be the culprit. If you have questions about the center carrier bearing, let me know. I had a thread on here earlier about it and had mine replaced. It got rid of a lot of shudder.
Another thing to look into is the motor mounts. They may be attributing to the shudder.
Just a few more ideas.
mrfix
Feb 13, 2013 10:41 AM
DarthMelvin
1997 - 2003 F150
Nov 2, 2008 09:06 PM
aerostargal
Aerostar
15
Dec 10, 2003 12:02 PM
Santa2ya
Jul 10, 2003 06:38 PM
62BigBlue
Jul 9, 2003 02:47 PM
