7.3 diamond eye downpipe
Old May 27, 2014 | 04:38 AM
new7.3owner's Avatar
new7.3owner
Is there a difference between the aluminized and stainless downpipe besides what they r made out of
Old May 27, 2014 | 06:24 AM
fordpride's Avatar
fordpride
Nope. They are made the same.
Old May 27, 2014 | 07:31 PM
IDMooseMan's Avatar
IDMooseMan
I have a Diamond Eye aluminum system. It is fine, but I originally ordered the stainless steel system, but received the aluminum one. The shop installed it, gave me a discount on the quoted cost, and that was the last I heard from the shop and Diamond Eye. If I had to it over again, I would've gone with the MBRP product.
Old May 27, 2014 | 08:21 PM
martin72's Avatar
martin72
I just got my (Stainless) Diamond eye Down pipe and exhaust on my truck and I love it.
Old May 30, 2014 | 11:22 PM
cowmilker08's Avatar
cowmilker08
FWIW, MBRP down pipes are known to be a bit more difficult to install. I'd stay with the diamond eye.
Old Jun 1, 2014 | 04:49 PM
Vibrant93's Avatar
Vibrant93
I'm about to pull the trigger on a system and am curious as to what you mean by this? Thanks.
Old Jun 1, 2014 | 06:22 PM
martin72's Avatar
martin72
When I bought my Diamond eye system I did a lot of research on here and there was others that said the MBRP down pipe did not fit as good as the diamond eye. That is the reason I when with Diamond eye and it went on and fit good. I did have to use a portapower on the fire wall but no matter the system your going to have to do this. Don't use the clamps that come with the system they make it very hard to remove the down pipe after you clamp them. Buy band clamps this makes it much easier.
Old Jun 1, 2014 | 07:24 PM
fordpride's Avatar
fordpride
I've looked into this a lot. It seems that most people that had a issue with MBRP had a ZF5
I've installed 3 MBRP pipes on 3 different trucks that had the E40D and none had fitment issues
It would be nice to see a MBRP and a diamond eye side by side for a comparison
Old Jun 1, 2014 | 08:35 PM
cowmilker08
I installed both brands on E4OD trucks and the diamond eye is easier for whatever reason. I used the same tools and technique for both jobs. The MBRP works fine but it just took a little bit more work, time and frustration to get installed.
Old Jun 1, 2014 | 10:39 PM
LeoJr's Avatar
LeoJr
I believe that stainless is a much poorer conductor of heat than aluminum. If this is true, stainless does not dissipate heat as quickly as aluminum. Reducing the amount of heat an exhaust systems dissipates is the reason for applying header wrap and ceramic coating.
I know that when I climb under my truck with completely stock exhaust, I am always surprised at how hot it isn't.
If/when I buy an exhaust upgrade, it will be stainless.
Old Jun 2, 2014 | 04:09 PM
martin72's Avatar
martin72
Here are some pics before I installed my exhaust. I polish the whole system before I installed it.
difference between factory 3" 1/2 and diamond eye 5"
Down pipe installed
Picture of the 5" installed
Down pipe from bottom.
Removing old down pipe.
New exhaust as I received it from RiffRaff.
Old Jun 2, 2014 | 10:15 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
I love the attention to detail on your truck. Nice job
Old Jun 3, 2014 | 08:49 PM
coreyallan01's Avatar
coreyallan01
I love 5" exhaust!
Old Jun 4, 2014 | 05:52 AM
tshrager's Avatar
tshrager
X2!!!
I know I shouldn't park my turd next to Kevin's at RRE!
Old Jun 4, 2014 | 06:43 AM
MOOSE_MACHINE
Originally Posted by tshrager
X2!!! I know I shouldn't park my turd next to Kevin's at RRE!
Comparing to Kevin's truck mine would probably belong in the junk yard. I don't know whether to laugh or cry right now
