Fuse Pannal Melt Down
Hi everybody
I have tow things that i hope some body helps me with.
1st I have 2000 4X4 LIMITED FORD EXCURSION 6.8L and today while i was troubleshooting a fuel pump issue (using threads in here thanks to u wonderful people)
I went through all fuses checking them that is after i checked the FP relay behind the radio i found what appears to be a milt down on the upper section .
Fuse number 14 is the worst as shown in the pics.
The thing is that every thing related to those fuses is working including the PCM (i used my scanner to read the trouble code i have now P0232).
P.S does any one knows what the hick is going on? and is it related to my fuel pump issue?
and my second question is related to the red arrow where does this wire or pipe goes and why is it cut (i never notice it until today. it is located under hood on the drivers side.
Thanks a lot for this great forum
update
the fuse box seems to be ok the only effected one is the 15 amps fuse No 14
But i cannot use it since the clips were damaged i tried to find those clips for the fuse but no can do (I live in middle east and my car is rear).
Is there any way of rewiring that fuse or move it some where else.
P,S Any advice will help.
No Solution!!!
Ford'05HG
superdave02f552
thank u both for replying
superdave02f552 that is not the issue with me there was no leaks (thanks god).
any way i think this will do for the time being.
here is my UPDATE
I connected an extension to the fuse connection pins after i cleaned it.
is that ok for temp repair until i could get my hands on a new or used CENTERAL JUNCTION BOX CJB.
superdave02f552
here is my UPDATE
Hey I parted out a 2000 limited recently, I sold the body to another guy that I became good friends with in a short period of time let me ask him if he has any plans for the fuse panel if not I will send it out to you.
Side note I wish I could get this old timer on here he currently has 6 excursions that he bought as salvage and is fixing all of them in one way or another with parts from my truck it is crazy.
The best one is the 42 k 2004 that he just got something fell on the roof and he will section part of mine in.
Ford'05HG
superdave02f552
here is my UPDATE
superdave02f552
here is my UPDATE
In the first pictures, it's hard to tell, but it doesn't look blue like the other 15 amp fuses. I realize it's burnt, but I think they had the wrong fuse installed. Also the #13 fuse above it had a 15 amp fuse instead of the 20 it should have. If it had a short and a larger fuse was put in, that could be the cause of the excessive heat without blowing the fuse.
I live in Middle East in Saudi Arabia and i did not not like small cars and i want to be distinguished so the X was for me was as a gift from ford so I bought a 2000 4X4 LIMITED FORD EXCURSION and from the first sight it was love with that elegant beast.
And since this car is rear in my country (people here do not like cars which r not popular due to spare parts issues and maintenance) most workshops and technicians tend to avoid having my car fixed in there shop (by the years I found out that even ford dealer techs have no clue or very little about most systems in the car and lots of issues emerged between me and ford main dealer in the capital city Thaw it is one of the biggest Arab golf countries capital I live in middle east in Arab golf) .
Finally ford stopped selling this model and I was left with MORE than one issue especially spar parts even ford dealer will not order any unless i agree to pay shipping charges plus the already high priced part.
I knew from the beginning that it was up to me to take care and maintain my monster (and I think I did fairly good having almost 500000 KM and still smoothly running ) I even have 3 tunes for my X and did some upgrades.
so I don't miss any chance from any source to help me do it (OWNED Ford Workshop Repair DVDs 97-2004 models plus a HAYNES MANUAL (Ford Super Duty Pick-up and Excursion Haynes Repair Manual covering all Ford Super Duty F-250 and F-350 Pick-ups and Excursion models for 1999 through 2004 plus googling the net ) and from there on I gave no excuse to any tech or mechanic the chance to say (( sorry sir we are not familiar with your car because I get ready before going to them by reading and gathering info and pics (even you tube videos ) then I stay with them to translate and explain manuals or procedures in Arabic for my country people or English for other incomers.
And that is why i DON'T want to trouble u
but if u can get the peace from your friend and there is a way so i pay the shipment fee that will be gust great (CJB price from dealer here is about 550$)
It should be fine as long as you make sure the wires in the fuse slot cannot make any connections. That fuse burned up for a reason and if it runs without a fuse it might burn up way more. What does the fuse power any ways? Is it absolutely necessary to have it in there currently? You should seek out the root of the problem before ever replacing things because there could be a lot more you would need to do to make sure it's safe.
and yes it was my mistake (my sun reminded me lately ) i was on a trip in the desert and had a 15 amps fuse short out and yes i did replaced it with a a 25 amps fuse to be changed as soon as i get home but it just went black on my mind.
I will say yes to that because it is for Dome Lamp, Cargo Lamp, Courtesy Lamps, Running Boards, Power Mirrors, Vanity Mirrors, Map Lamps, Under-hood Lamps, Glove Box Lamp,an most important Power Windows (Delayed
Accessory).
thanks alot for your advice i will pay more attention in the future.
thanks for noting that
nmclella
04-14-2015 02:56 PM
