1978 - 1996 Big Bronco
1993 Ford Bronco
Old May 26, 2014 | 03:55 PM
Deadsquiggles's Avatar
Deadsquiggles
1993 Ford Bronco
Just got a 1993 Ford Bronco with the 302. I was wondering how I can find the axle ratio. The only way I could find was a build sheet and that cost $18.
Thanks in advance,
Tommy
Old May 26, 2014 | 04:27 PM
Fordman96's Avatar
Fordman96
There are a few ways to look.
1) Axle ID tags on the axles.
2) Vin decoder on this site
3) Remove the diff covers and count the teeth, but it'll be hard to count the pinion gear.
Old May 26, 2014 | 04:29 PM
Deadsquiggles
How do I did the vin decoder on here? I'm on my phone. Or do I have to be on a computer?
Old May 26, 2014 | 05:29 PM
Fordman96's Avatar
Fordman96
You might have to go on the computer. Let me find a link.
VIN Decoder - Ford Truck Enthusiasts Forums
Old May 26, 2014 | 05:40 PM
Deadsquiggles
Awesome, that gave me everything I was looking for, except one thing. Do I have a limited slip or not.
Old May 26, 2014 | 06:43 PM
f100beatertruck's Avatar
f100beatertruck
What's the code on the door say?
Typically if they start with a letter it's a limited slip.
Old May 26, 2014 | 06:59 PM
Deadsquiggles
It starts with a 1 so I guess open differential?
Old May 26, 2014 | 09:13 PM
Fordman96's Avatar
Fordman96
http://www.differentials.com/technic...identification
Old May 27, 2014 | 10:27 AM
Conanski's Avatar
Conanski
Yes, go open the drivers door and find the certification label on the door frame or end panel... looks like this..
get the axle code and compare to this chart.. Ford Axle Code Chart | Ford Trucks
Old May 27, 2014 | 10:18 PM
Deadsquiggles
Another question. The 4wd floor shifter linkage is disconnected.
Does anyone have a picture of this put together how it's supposed to be? Or at least tell me how it supposed to go back together. I really need my four wheel drive for the summer since I drive take my truck down to Rodanthe and drive on the beach.
Old May 28, 2014 | 06:52 PM
Deadsquiggles
I figured out that the piece was broke. Another question. How do I know if I have the E4OD or AOD transmission? All information plaques and panels have been removed.
Old May 28, 2014 | 07:31 PM
Fordman96's Avatar
Fordman96
I believe it should be under the vin identification.
Old May 28, 2014 | 09:27 PM
Encho's Avatar
Encho
The Southernmost Mod
1993 should all be E4OD, it's also easy telling them from the cozy cab, if the shifter lever has an OD-OFF button in its cap then it's an E4OD for sure.
Old May 28, 2014 | 10:16 PM
Deadsquiggles
Ok then I for sure have a E4OD.
And a funny thing happened today. I was messing with the linkage in the above picture and unknowingly kicked the transfer case in between 4Hi and neutral but close enough to 4Hi for me to turn out the driveway, wondering why the steering was binding up some, get going down the road and then kick into neutral two blocks from home. Of course, not knowing what happened and not having the money for a new t-case or tranny, I freaked out thinking I had smoked the t-case or tranny. My neighbor came and looked and got it into 4Lo which got me home. Thankfully, once I got in my driveway, he got it into 2Hi. I really need to get that linkage fixed.
Old Jun 19, 2014 | 10:22 AM
95F-150Project's Avatar
95F-150Project
Is the E40D a good transmission to have?
