Improving MPG
Old May 26, 2014 | 01:25 PM
CoachCL's Avatar
CoachCL
Improving MPG
I want to start this by saying this is my first diesel motor to own. I have replaced some fairly simple things on trucks in the past such as starter, alternator ect. But do not have much experience making modifications.
With that being known I have read several threads where guys mention mods they have done to help improve their MPG, what are some of the things you guys suggest I do first. And is it something I can figure out how to do myself or do I need to pay a professional. I am buying a house soon and I would like to be able to save the money and do it myself if possible.
Old May 26, 2014 | 01:58 PM
Christof13T's Avatar
Christof13T
Not to be an a$$ but this topic has been beaten to death... resurrected... beaten to death again... and on and on.
Start by reading through all the tech links in the link at the top of this forum.
Get your engine 100% happy before chasing mpg ghosts.
Until then your just spinning your wheels and throwing parts/mod money in the dark.
Old May 26, 2014 | 02:20 PM
Tugly's Avatar
Tugly
"Spinning your wheels"... that's apropos.
Rule 1: Like Chris says, get the truck to 100% - the factory did it right.
Rule 2: Be boring. If it's fun to do with your foot, it's bad for economy. So if you like to dance, just make sure there's no Superduty under your feet when you do it.
Rule 3: Skinny tires. Many are under the impression tall tires really hurt economy. Recent events may indicate tall tires are usually fat as well, so width may have more impact on MPG than diameter (assuming the speedo is adjusted correctly). There will be those who say it looks like crap, but you can say that about their fuel bill - while sitting atop a set of 245/80R16 pizza cutters.
Rule 4: Less weight, lower suspension, put in air dams and skirts. Basically convert it into a ricer... or acknowledge the fact that you just bought a diesel truck.
Old May 26, 2014 | 02:26 PM
Skip1970's Avatar
Skip1970
get a 2wd excursion, that would be a good start.
Old May 26, 2014 | 02:35 PM
Tugly's Avatar
Tugly
If you're getting 16-18 combination and 18-20 pure highway, that's a realistic peak without going extreme.
Old May 26, 2014 | 06:02 PM
hydro man 17's Avatar
hydro man 17
As mentioned above it is a truck, you are basically shoving an 8 K/LB brick down the road. If you see MPG as Rich stated above BE HAPPY.
Old May 26, 2014 | 10:15 PM
auden's Avatar
auden
Tuck in the mirrors, drop the tail gate, maintain proper tire pressure and find the sweet spot for mph probably around 60. Save your money!
Old May 27, 2014 | 07:04 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
The sweet spot for BEST mpg is right after it goes into OD, about 46 mph. Of course you will get killed on the interstate, but if you can drive country roads to work with no stops, it's the way to go.
Old May 27, 2014 | 07:50 AM
Tugly's Avatar
Tugly
...drop the tail gate....
Sorry to dispute you, but this one is a myth... it was covered on Mythbusters.
Old May 27, 2014 | 08:05 AM
River19's Avatar
River19
You beat me to it.....
IIRC having the tailgate up in its normal position with an open bed creates a vortex of swirling air in the bed (think about how the leaves blow out of your bed if you drive down the road......usually up in front of the rear slider). That air bubble allows airflow from the front of the truck to actually slip over the cab and continue right on off the back of the rig. Pulling the gate allows that frontal airflow to actually drag along the bed more and create more drag as the vortex is not created.......
Or something like that.
Old May 27, 2014 | 08:20 AM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
As once was quoted to save fuel, Drive like you have an egg under the pedal. To burn fuel crush the egg.
Best I can get is about 20-21 but that is driving on the interstate at 62 for a very long time. I am happy with the 18-19 when traveling at 70-75 so I don't worry about it. Recently mileage has been slipping, but that has more to do with me mashing the skinny pedal harder than normal and some additional maintenance items needing some TLC. Get the truck to a point where nothing is leaking and then act like you are going to break an egg when you mash the go pedal and you should see some improvement. Maybe not much but a little. But then again, what fun is that. I am averaging around 15 traveling back and forth to work.
Old May 27, 2014 | 08:32 AM
CoachCL's Avatar
CoachCL
I am getting 13-15 on the Highway, I would be a happy guy if I was getting 18-20.
As for this being beat to death on here I assumed that was the case but I was on my phone at work and having trouble navigating the search feature to find the discussions.
Old May 27, 2014 | 09:30 AM
Tugly's Avatar
Tugly
Originally Posted by CoachCL
I am getting 13-15 on the Highway....
This falls squarely under the returning your truck to 100% category. A stock truck (with stock tires and suspension) will give you the numbers I mentioned - when in proper running condition. Snake oil and magic technology can actually make things worse.
So... the thread should actually be about restoring your fuel economy. A scan tool is very helpful with this, and we know you have a smart phone. Is it Android (torque Pro) or iOS (Dash Command)? Get yourself an OBDII adaptor (Chinese knock-off $20, proper unit $100) and you're less than a Hamilton from a scan tool.
Old May 27, 2014 | 09:31 AM
Christof13T
I did not mean it as a personal attack in any way...
It just gets tedious seeing the same discussions over and over under new threads.
This particular topic has been dragged through the mud so many times, when it is brought back up... pretty much the exact same generalized statements are made.
Mayhap we should get a mpg only questions stickie?
Old May 27, 2014 | 09:41 AM
Smokiesman's Avatar
Smokiesman
The OP did not say what he was driving? Is it a 2wd 4x4 what year ? Gearing can be a difference ! But I concur with the previous posters on havin the truck a 100%.
Smokie
