I'm wondering if this may be the anser to the problems I'v been haveing? I get full Blast heat on all heater, vent, & a/c settings - off & max a/c. When I set to off I get nothing as I should and on max a/c I get cold air. All the other settings give me boiling heat no matter where I set the blue to red temp. ****. I'v located the valve in the coolent lins running to the heater core And it opens allowing hot coolent into the core on all settings but max a/c & the off position. If someone could let me know if the fix listed in the sticky post is what I need too do.
It sure sounds like it is. That's how mine was. The sheet about the fix describes how to check to make sure that that is the problem without going into too much surgery (basically, you have to pull off the actuator through the glove compartment opening and use a dental mirror to inspect the blend door.
