Something cool that I picked up
Old May 23, 2014 | 12:47 AM
d-day's Avatar
d-day
Well figured if I wasn't pulling my car trailer I would have this setup in the bed
Picked this little jewel up from a older couple. Since I didn't feel like sleeping on the ground anymore and I was due for a new tent, lol. I picked it up for $500! Yes everything works in it , the refrigerator was replaced about 6 or 7 years ago. I was mainly looking for something to get out of the weather. The only drawback is that the front window leaks, because it is missing how about an inch and a half of the seal, no water damage as it was parked under a cover for the last 2 years. Anyway figured I would just post up just because, just to show that the old girl is still working :-) fully loaded with water and gear camper ways in roughly about 1500 pounds..
Old May 23, 2014 | 05:24 AM
Prototypemech's Avatar
Prototypemech
Very cool. Looks like an 1988. I got a very similar 8ft sixpac a few months ago for a similar price. Your windows are alittle different so you must have a different layout. Goy any pics of the interior?
Old May 23, 2014 | 10:32 AM
d-day's Avatar
d-day
Yep its an 88, I'll snap some pictures this afternoon. Since you have about the same setup, where in the heck are the hook up for 12v? I have a round 4 pin on the driver front but I believe its for the running lights
Old May 23, 2014 | 01:15 PM
Prototypemech
My setup has a 7 pin trailer connector that supplies 12v power, running lights, and ground. It exits from the cubby under the refrigerator and runs to the back of the bed to the normal 7 pin trailer connector. I installed a 100 AH agm battery near the fresh water tank and i have solar panels to charge the battery during the day and the trailer-battery-charge system while the engine is running. You can modify the trailer-battery-charge system to supply constant power by removing the relay and installing a copper strip. Do you have a bathroom/shower in yours? Mine does which shrinks the dining seats down. Heres an exterior photo of mine. It weighs 1750 lbs according to the tag. Whats yours weight?
Old May 23, 2014 | 01:18 PM
Prototypemech
https://www.ford-trucks.com/forums/showthread.php?t=1309881&page=10#PhotoSwipe1400868 302709
Old May 23, 2014 | 03:21 PM
d-day's Avatar
d-day
I'm still working lol I'll take some pictures. I looked again for a plug I didn't find one, so I think I'll run new 2ga wire from the batteries to the 12v panel with a on/off switch..
Here's the batteries I'm using
I get them from work for free
I'm using 3 in par not series
Old May 23, 2014 | 03:35 PM
Prototypemech
You could always follow the 12v electrical wires in the cubbys ans see where they exit the camper.
Old May 24, 2014 | 12:03 PM
d-day's Avatar
d-day
I ended up finding the 12 volt hook up.. And they also tied in the running lights to it as well, kind of dumb really. So I am going to run the wires back inside by the converter so I can keep two batteries inside opposed to in the bed, doing some work today. Going to reseal the front window
Old May 24, 2014 | 11:03 PM
racer30's Avatar
racer30
Someone has re-worked the front of your camper. No problem fixing it, because you got a good deal on it.. Way better than sleeping on the Ground.
Old May 24, 2014 | 11:18 PM
d-day's Avatar
d-day
Reworked? Can you please explain a little more on that, as this unit is new to me
Old May 24, 2014 | 11:32 PM
racer30's Avatar
racer30
That wood I can see in the picture of the front overhead is not stock to that Camper...Someone has put what looks like thin tongue and grove wood up there to cover up the rotten wood panel that was up there.
Old May 24, 2014 | 11:51 PM
d-day's Avatar
d-day
Oh yes, I did notice that when I was looking at it. I did ask about that because It was new compared to the rest of the camper, the older gentleman told me it was hit on the front and was repaired. I can see that from the roof if I'm standing on top of that you can see where it was repaired or re reskinned up front. Before i resealed the front window I washed the camper to also to check for leaks, the only one that was present was the front window. I took out the front window cleaned it and re sealed it, after sealing it this morning I checked again for leaks this afternoon and I have zero leaks now.. Well if anything if I get a few years out of it I would be happy with that, i was looking around the internet seeing what the cost would be if I had to replace the stove and oven combination or a refrigerator. The refrigerator is worth more than the whole camper lol
Old May 25, 2014 | 02:29 PM
jonathanpatr's Avatar
jonathanpatr
my plan
I want to do the same thing, not sure how my wife will like it, but the price is right when you are on the road!! Nice deal, thanks for the interior pics
j
Old May 25, 2014 | 02:47 PM
d-day's Avatar
d-day
j
No problem, wife wasn't a real big on it either until she found out I can still pull the car trailer behind it. And it has a heater lol
Old May 25, 2014 | 07:34 PM
Dieselamour's Avatar
Dieselamour
Cool. That is a nice SHTF vehicle
