400 Hard starting
Old May 22, 2014 | 09:26 PM
Davehart24's Avatar
Davehart24
400 Hard starting
Hello. im in the process of putting together my 1977 highboy with a 400 and for some reason every time i try to start it it cranks and cranks for minutes on end. The odd part is it will only start when i continually pump the gas, and i mean pump it ALOT. It has an edelbrock 600 cfm carb. I looked in the carb and pumped the gas and it sent out a nice stream of fuel so the jets are working alright. Whys it taking so much fuel to start? i even have to pump it a ton just a few minutes after shutting it off. Today i cranked it over so much that the new battery went dead. Also sometimes it will fire up the second i let off the key, almost like the starter it stealing the voltage so it wont start. Could this be timing maybe? thanks a lot, dave
Old May 22, 2014 | 09:33 PM
Davehart24's Avatar
Davehart24
also it seems to start a lot worse when its warm
Old May 22, 2014 | 09:50 PM
Blue and White's Avatar
Blue and White
Since you have verified fuel and pump shot I wonder if it is an ignition issue? Maybe check coil voltage when cranking... it should be around 7-8 volts. How about the ballast resistor (if equipped?).
Old May 22, 2014 | 10:50 PM
61steven's Avatar
61steven
Is the choke working properly?
henryfrick
31
Apr 23, 2017 11:51 PM
brian1080
Feb 11, 2014 11:59 PM
berry1234
Feb 5, 2011 04:16 PM
skipr
Dec 4, 2009 09:09 AM
Dilligas
Feb 5, 2004 05:24 PM
