Balancing 42" Tires??
Hell Everyone,
I got some 42" TSL Super Swamper with about 70% tread for my excursion for 300$ on CL a few months back. I've had them sitting around but just recently finally purchased 20x12 Fuel Octanes to get my X back on the road.
I found a guy that will mount them for me for 80$ (won't fit on machines) so it runs a little more. But he suggested I used balancing BB's or beads. They use it on all their trucks with offroad tires and semi's as well.
The fellow I purchased them from used the beads as there is still some left over. I'm just trying to figure out what I should do to balance mine. Most shops around here don't have machines big enough to do 42s.
What did some of you guys do on swampers 40" and up?
Thanks
Thanks
yeah BBs work just fine. I've heard of anywhere from 12oz to upwards of 16oz for your 42s (taking the tire diameter into consideration). there's all sorts of opinions on plastic vs ceramic vs steel... me I'd go with heavy plastic airsoft BBs .25g ones. this pack should be enough for all four tires. Airsoft Sniper Rifle TSD Black 6mm 25g Refill Pack 10000RDS Plastic BBs Slick | eBay oh and no amount of BBs or weights will smooth out out-of-round tires which do happen a lot more often on big MTs like those. i had a vibration i couldn't track down until i took my truck to a shop had them lift it up to get all four tires off the ground and put it in 1st gear Low. then with all four tires spining slow it was easy to see the wobble on one wheel. you can also use an indicator or even a pen/pencil taped to a chair and placed so the tip is almost touching the tire. I had an out of round wheel. Same thing happened to my dad with an out of round tire.
It could just be my eye playing tricks on me too
what did you guys do in the event of the out of round tire? Which would really suck. It looks like 1 of mine rolls at very tad bit different than the other 3. I don't even think they make the 42x15.5x20 anymore either so hopefully I won't have to buy 4 new ones. Don't have those kind of funds!
honestly you're kinda screwed. normally we just make that the spare and get a round tire for the truck. I've heard of places that can true up a tire some by scraping or grinding it round but i've never even talked to someone that's actually had it done so it could be a myth if it were me, if it's not too bad i'd just make sure to designate it as a rear tire only and deal with the slight vibrations. If it's really bad then.....
The machine that cuts your tires are actually spinning the tire while a blade is removing the uneven rubber (making it a perfectly round tire).
This process is not cheap, but the results are outstanding!
Road Trip!
on
This isn't my daily driver so I should be ok. I have a Ninja Zx10 I scoot around on and a bagged chevy malibu
This is my project truck
SeannyBoy84
09-29-2005 01:51 AM
