So my 1996 7.3 f250 has a problem.
The power window motor goes up but it doesnt bring the glass with it.
When it comes all the way up i see the plastic rectangle and it appears like that should be stuck to the glass, or under it.
Im not sure how where to put this piece so it brings the window up.
It seems like it is on track on the right hand side.
any advice would be appreciated.
Thank you!!!
take off your door panel, and noise barrier(black plastic) and you should be able to see where you need to reset the glass on the lifter, super easy and quick
