Sponsored by: Innova
CB Antenna install
Old May 21, 2014 | 12:01 PM
HP junkie's Avatar
HP junkie
CB Antenna install
I just installed a CB antenna (Wilson 2000) on my truck to the truck bed rail behind the cab. I tuned the antenna and best I could get was 2.8. Wondering if there is a better spot other than going to magnet mount. Thought about going a foot or two back from the cab but wanted to bounce ideas off of someone knowledgeable.
Old May 21, 2014 | 05:31 PM
barnettbill's Avatar
barnettbill
Make sure your antenna is grounded properly. You may have to scrape some paint to get a good ground.
Old May 22, 2014 | 11:49 AM
HP junkie's Avatar
HP junkie
Thanks! I will try that and test then try moving antenna away from the cab testing each time to see if I can find a good spot. Otherwise I might have to get a roof mount with quick disconnect.
Old May 22, 2014 | 05:55 PM
barnettbill
I have a stake hole mount with a firestik. I needed to scrape paint to get a good ground. Unless you are using an antenna that is a non ground plane, grounding is essential.
Old May 23, 2014 | 10:28 AM
HP junkie's Avatar
HP junkie
Good to know, Thanks!
Guessing that you have good signal even with it behind the cab.
Old May 24, 2014 | 02:44 PM
barnettbill
Yup. I can get out a few miles. More if I use SSB.
Old May 24, 2014 | 03:52 PM
arctic y block's Avatar
arctic y block
I was always told the best place was as centered on the rig as you could get.
That the rig works as a ground plane and to mount it to one side has a
tendancey (sp) to send a more directional signal than omni-directional
as it would be in the center.
Old May 24, 2014 | 05:47 PM
barnettbill
the vehicle does serve as the ground plane (that is why it is important to get a goo ground). And yes, centering the antenna does let you transmit better, but it is 2 different issues. Sometimes centering is not practical. And in my humble opininion the range gained is not that significant, I could be wrong.
Old Jun 8, 2014 | 03:31 PM
k-wtrucker's Avatar
k-wtrucker
Another helper is an additional ground wire that is hooked up to the frame. Also, check the match on the swr calibration...adjust as needed.
Old Jun 8, 2014 | 04:46 PM
barnettbill
I'll drink to that/
Fert
Jun 26, 2018 03:28 AM
johnny yahoo
Oct 14, 2013 05:13 PM
air1jpg
Jun 11, 2008 04:09 PM
pepito113
2004 - 2008 F150
13
Aug 14, 2007 08:50 PM
Buck000
Jun 23, 2003 02:44 AM
