reverse light diagram
Old May 21, 2014 | 10:56 AM
davidwjacob's Avatar
davidwjacob
Hello all,
does anyone have a reverse light diagram. The truck im picking up tomorrow is a 1991 f350 7.3 ID 5speed man, DRW. and the reverse lights dont come on anymore when it goes in reverse, im hoping its just a sending switch or something.
let me know if you have a diagram or where the reverse light switch is please.
thanks
Dave
Old May 21, 2014 | 12:19 PM
madpogue's Avatar
madpogue
Diagram is at home. But it's pretty simple - fuse (should be in the owner's manual) -> wire -> switch on tranny -> wire -> rear harness connector -> lights. Switch is on the driver's side of the tranny; it's the only electrical thing on the tranny.
First thing to try is disconnect the switch, then put a jumper wire between the two terminals on the connector on the harness, then turn the key to RUN and see if the lights go on. If they do, bad switch, cheap at RockAuto, should be readily available at FLAPS.
Old May 21, 2014 | 12:43 PM
davidwjacob
thanks for the info
Old Jul 22, 2014 | 06:08 PM
davidwjacob
How does the switch come out? Turn or is there a clip or?
Old Jul 22, 2014 | 06:27 PM
madpogue's Avatar
madpogue
It threads in. The whole switch is a hex head.
Old Jul 22, 2014 | 06:58 PM
bashby's Avatar
bashby
IIRC the switch is located high on the drivers side of the trans, toward the front. It can be hard to see. 2 wire connector.
Old Jul 23, 2014 | 01:57 PM
davidwjacob
i got the connector off and the connector is shot, its all rotted and broke. if i jump the wires together my lights work. so i am ordered a new switch and connector from napa and will get them in tonight.
thanks
Dave
asalinasz73
15
Jan 4, 2018 11:31 AM
jwhopson
Dec 31, 2013 12:53 PM
chollyb
Bronco II
Jan 25, 2013 11:38 PM
pepsiguy
Large Truck
Sep 14, 2011 06:50 PM
Lifted94XLT
Kansas Chapter
18
Mar 9, 2004 11:39 PM
