Yet another Wiring Question
Old Mar 7, 2004 | 04:40 PM
Lifted94XLT's Avatar
Lifted94XLT
Unhappy Yet another Wiring Question
alight y'all, I got bored on this mighty nice day so I decided to use one of my driving lights which I no longer have use for, as an aux. reverse light, I got it wired and it works. (But I wired it up so it comes on with the reverse lights) Now, question time.......
I want to keep it so that they always come on with the reverse lights, but I also want it to come on with the flip of a switch (tailgaters ) So how do I wire it to where, when the switch is in the off posistion, the light works with the factory lights, but when the switch is in the on posistion, the turn on?? Do I need a special switch to do that?
Thanks for anybody's help in advance.
--Ryan
Old Mar 7, 2004 | 06:51 PM
Ultramagdan's Avatar
Ultramagdan
You don't want to flash tailgatters. It's illegal. Flashing someone at the wrong time can blind them and cause a nasty accident. I would leave it for only reverse.
With that said you would need to wire in a separate switch.
Please don't flash me, I'm only trying to get around and on down the road.
Old Mar 7, 2004 | 06:53 PM
Lifted94XLT
people take me too seriously... it would also be for light while working at night too.... but anyway...
I know that I need to wire in a seperate switch, but my quesiton is, ho do I go about doin it.
Old Mar 7, 2004 | 07:42 PM
Ultramagdan
I think you might need a seperate switch. Something like a 3 way I think. If I told you how to wire it I would be wrong.
A power line through the switch to the light.
Your back up power line through the switch.
You can get one at Radio Shack and they could tell you how the thing would wire up. Without instructions in front of me I'm dangerous.
Old Mar 7, 2004 | 07:49 PM
Lifted94XLT
lol, thanks man. If somebody has another schematic for me, that would be great. I only wanna use a single throw switch at all cost.
Old Mar 7, 2004 | 07:55 PM
mitch5170's Avatar
mitch5170
Pretty simple, just take +12v thru a single pole switch, and run it to the light, splice it in with the wire from the reverse lights.
Not sure how many amps the aftermarket lights pull, but if it gives you any problems, you might need another relay.
Old Mar 7, 2004 | 08:08 PM
Lifted94XLT
they are a 15 amp light, but I'm also gonna fuse it. so I need a single pole, single throw switch, then I take the power from the light and run to the switch, the run the load from the switch to the factory reverse lights? and then of course ground both teh switch and the lights? Do I have that right?
Old Mar 7, 2004 | 08:21 PM
mitch5170's Avatar
mitch5170
Think of it this way....
12v+ from factory reverse---------Lamp---------ground
12v+ from battery---switch-------/
No need to ground the switch, just run 12v thru it to power the lights, the lights are already grounded
Old Mar 7, 2004 | 08:25 PM
Lifted94XLT
ok, I think I may get it, (Sorry, I"m slow at this) I'm amkind a schematic of what I think I need to do... once again Mitch, sorry for my stupidty and being patient. I jsut wanna make sure I do this right.
Old Mar 7, 2004 | 08:33 PM
Lifted94XLT
Is this even close to what you said?? ::
Old Mar 7, 2004 | 09:15 PM
Ultramagdan
Will this turn on his back up lights? That was the reason I mentioned the 3 way switch. That way he could have:
1) aux lights on in reverse
2) aux lights off in reverse
3) aux lights on and backup lights off
Old Mar 7, 2004 | 09:18 PM
Lifted94XLT
I just want it so that when the switch is off, the aux. light turns on only in reverse, but when the switch is turned on, the aux. light turns on, like a regular aux. light would.
Old Mar 8, 2004 | 12:18 AM
dragonslayer's Avatar
dragonslayer
Leave it on single throw/pole it will come on when you go into reverse,just like on an ambulance. With the switch you can manually turn it on.(that is if you tap into your reverse lights)
I would suggest that you just wire it seperate, and run it from inside the cab, that way you don`t ruin you backup indicator.
Old Mar 8, 2004 | 12:25 AM
Lifted94XLT
well, I've already got it wired. lol... but earlier tonight, I notcied its not very bright at all? is that maybe b/c the wire that I tapped into can't handle the voltage of the light AND my reverse lights??
Old Mar 8, 2004 | 03:34 AM
Lifted94XLT
Here's a couple pics of its brightness.... should it be brighter than that you think (its a 55w light)
