Exhaust manifold problems
Old May 19, 2014 | 07:29 PM
The FNG's Avatar
The FNG
Please see pics and help me go foreword with this. On each bolt there is bout 3/8" or more to work with. Both pics are the same bolts, just slightly different angles.
Old May 19, 2014 | 10:30 PM
Crewcabber's Avatar
Crewcabber
Do you have access to a welder? If so weld some nuts on them. And spray some blaster on them and work them back and forth. If not hear them up and try and work them back and forth. I don't know how flammable on blaster is so be careful. Patience is gonna be your best tool on this job.
Old May 19, 2014 | 10:36 PM
eakermeld's Avatar
eakermeld
Use a stick welder, not a wire (MIG) welder and run it on reverse polarity with the proper rod for doing so. I have welded nuts to dozens of twisted-off bolts and this way works best. By the way, you are lucky. They usually twist off flush with the head!
Old May 19, 2014 | 11:29 PM
The FNG's Avatar
The FNG
I've got a stick welder, but it can't access the truck. Also, it's an AC welder so I can't do reversed polarity. I read about melting wax on them when they are hot so I will try that. Been using heat and kroil for a few days, but it just didn't get all of it. I may try vice grips too.
codafisler
Apr 13, 2012 04:32 PM
Lowboy44
Feb 26, 2012 08:49 PM
Nod
Exhaust Systems
Apr 13, 2010 12:18 AM
got2lb
Exhaust Systems
Sep 16, 2004 01:54 PM
homoudont
Nov 22, 2003 07:05 PM
