What fluid is this?
Old May 19, 2014 | 04:03 PM
jaywhy's Avatar
jaywhy
What fluid is this?
Ive been lurking for a while gathering info about my truck learning as I go. Thanks to this site I was able to fix the dreaded dipstick flange leak on my own. I now noticed a few drips under my truck while parked on a drive. I climbed under and found where the leak was coming from. Im not sure what the fluid is....maybe diesel? I think I found where it was dripping from and gave it a bit of tightening and I guess Ill see if that works or not.
Thanks Guys!
20140519_163512_zpsaa5be2b8.jpg Photo by jaywhy19 | Photobucket
20140519_163514_zps283c7500.jpg Photo by jaywhy19 | Photobucket
Old May 19, 2014 | 04:28 PM
helifixer's Avatar
helifixer
looks like a coolant leak coming out of your block heater, also looks like your oil cooler needs re sealed.
farmert's Avatar
farmert
If it was leaking from the fitting on the orange cord, that is the block heater, and the fluid is coolant. It also looks as if the oil cooler o rings are seeping a little oil.
Old May 19, 2014 | 06:00 PM
jaywhy's Avatar
jaywhy
I do think it was coming from the fitting! Ill have to look into getting the O rings replaced at some point.
Thanks for the quick responses!
trike1946
Oct 4, 2012 04:57 PM
mblanken881
Dec 27, 2011 11:07 PM
2FordTrucks
Jul 18, 2011 04:23 PM
Joe_D
May 31, 2008 06:06 PM
banginona40
Apr 19, 2008 01:31 AM
